1. Thanks for your reply. But, do I have to edit any startup file for my problem? I am trying to understand if editing startup file necessary or optional.
2. I have a query regarding the output of sysload (given below):
SYSLOAD: Task dump
SYSLOAD: Load Stack left Name
SYSLOAD: 2.98 175 Tmr Svc
SYSLOAD: 69.16 127 IDLE
SYSLOAD: 2.53 207 FLOW
SYSLOAD: 0.0 75 PWRMGNT
SYSLOAD: 1.01 214 CRTP-RX
SYSLOAD: 5.94 169 SENSORS
SYSLOAD: 2.15 77 ZRANGER2
SYSLOAD: 0.0 220 MEM
SYSLOAD: 0.0 109 LOG
SYSLOAD: 0.0 91 PARAM
SYSLOAD: 0.0 177 LH
SYSLOAD: 0.05 158 SYSTEM
SYSLOAD: 0.04 62 CRTP-TX
SYSLOAD: 2.96 20 SYSLINK
SYSLOAD: 4.64 311 STABILIZE
SYSLOAD: 8.47 258 KALMAN
SYSLOAD: 0.0 113 USBLINK
SYSLOAD: 0.0 204 CMDHL
Please help me understand the meaning of this. I see different task at the right, and there are stack left for each of the tasks. Does this mean this much stack is left in each task? Which one is the stack available to use? And, also what is the unit of 'stack left'? Is this in bits or bytes or something else?
Regarding the other questions:
3. Yes, you are correct. storage wise, CCM is enough. But, I went to the linker file
https://github.com/bitcraze/crazyflie-f ... F_CLOAD.ld and I have following queries:
3.a) there is no entry of ccmram here. So, does this mean, the ccmram is not activated by default, and I have to activate this by adding proper line?
3.b) it told me not to do any edit in this file as it will be erased at every link. I am not sure what it means? Can I not edit this file to do my work? I was thinking about editing this file for CF2.1, but this statement made me confused. I am a bit novice in this computer architecture avenue, hence some walk-through would be very helpful (if this is ok, ofcourse).
Thanks
