Access to tick from another source file.
imranmomtaz
Post by imranmomtaz »
I am trying to access live tick value from another source file (connected with a task priority 2). So far, I have wrote the following:
in stabilier.c file:
uint32_t tick;
uint32_t *pTickPTR = &tick;
in other source file (lets assume filename: cf.c)
extern uint32_t *pTickPTR;
uint32_t tick;
while(1){
tick1 = (*pTickPTR);
LOG_GROUP_START(KFChk1)
  PARAM_ADD(LOG_UINT32, tick, &tick1)
LOG_GROUP_STOP(KFChk1)
The output of the this program is given below:
stabilier.tick = 2, KFChk1.tick = 0
stabilier.tick = 3102, KFChk1.tick = 1869
stabilier.tick = 3112, KFChk1.tick = 1869
stabilier.tick = 3122, KFChk1.tick = 1869
stabilier.tick = 3132, KFChk1.tick = 1869
Please let me know what I am doing wrong and suggest how I can access this. Thanks a lot.
wydmynd
Re: Access to tick from another source file.
Post by wydmynd »
first, you are using PARAM_ADD where LOG_ADD should be
second, you can use log variables to internally transfer data between tasks, also RTOS queues are used
I didn't use pointers so will be also interested to hear if this is supposed to work
imranmomtaz
Thanks. Can you show an example about how log variable can be used to transfer data between tasks? Thanks a lot!
When transfering a single word of data from one thread to another you could just declare it as extern, without needing to use a pointer, log or anything else:
// In stablizer.c:
uint32_t my_tick;
// in another file
extern uint32_t my_tick;
// From here, accessing my_tick does access the my_tick variable form stabilizer.c
If a variable is to be used only in one file, it should be declared as "static", otherwise it is shared with all the files. In your original message you would have a problem with the tick variable that is declared as non-static in two different files.
There is also a way to declare and access log variable from within the firmware, depending of what you are trying to achieve it might be overkill though, sharing a variable between two files is handled by C itself. An example of how to read a log variable from within the firmware can be found in the app examples: https://github.com/bitcraze/crazyflie-f ... aram_api.c
As a last note, if you want to share more than a single 32bit variable between thread, you will need some kind of synchronization, either a mutex or a queue. There is a lot of code in the Crazyflie that you can look at that already uses FreeRTOS queues and semaphores/mutexes. The FreeRTOS doc is also a good place to look at to find more information.
imranmomtaz
Thank you.
