Make your own CF Client exe
Posted: Sun May 05, 2013 3:32 am
i want to share my first experience to build a CF_Client.exe with py2exe and NSIS ( creates Windows installer).
I use Win7 with Eclipse and Git(Addon) for development.
What you need is:
1. All Libraries from the Wiki for CF Client development
2. PY2EXE for py2.7(win32)
3. NSIS Compiler ( creates Windows installer if needed)
(If you get error about missing dll, download and install the Microsoft Visual C++ 2008 Redistributable Package)
Because of include errors in setup.py (rev103) i have to change "options" (from line 44) in setup.py as follows:
After these changes you can run (in Eclipse) "/crazyflie-pc-client/setup.py" as Python RUN with the Argument "install" (see RUN Configurations -> Arguments) and then run setup.py again as Python RUN with the Argument "py2exe".
Now you can find the exe at "...\workspace\crazyflie-pc-client\dist\cfclient.exe".
If you want to make an installer of it run ".../crazyflie-pc-client/win32install/generate_nsis.py" as Python RUN and compile the generated "cfclient.nsi" file (same folder) with NSIS (context menu in Windows File Explorer).
I don't know if py2exe and NSIS are already in the VM?
What you need is:
options={"py2exe" : {"includes" : ["sip", "PyQt4", "cfclient.ui.widgets", "cflib.bootloader.cloader",
"cfclient.ui.toolboxes.*", "cfclient.ui.*", "cfclient.ui.tabs.*",
"cfclient.ui.widgets.*", "cfclient.ui.dialogs.*", #"pygame._view",
"excludes" : ["AppKit", "PyQt4.uic.port_v3",
"dll_excludes": ["MSVCP90.dll"],
"skip_archive": True,
}}Now you can find the exe at "...\workspace\crazyflie-pc-client\dist\cfclient.exe".
