Getting VM 0.5 to work with VMWare Workstation 10
Posted: Fri May 16, 2014 4:41 am
Okay, I pulled down the VM 0.5 and discovered absolutely no love for it from VMware Workstation 10.0.
Here's how to fix:
1 When you import the OVA file, you will get a warning about failure to import. That's okay, hit 'Retry' and it will relax the restrictions and allow the import to work.
2 Modify your virtual machine settings. I removed the hard drive and re-added as the 'recommended' which was the LSI SCSI. (I don't know if that was actually required). I also did not choose to 'upgrade' the file system. Also, I don't think that was an issue.
3 Don't forget to add a CD-ROM drive to your VM, you'll need it later.
4 When you start, you'll see a brief flash of the start up screen from Xubuntu, and then blank screen.
5 Press 'CTRL-ALT-3'. This will get you a terminal prompt. Log in with supplied account ( see VM download page for account/password).
6 Remove Virtual Box stuff.
7 Go to your VMware Workstation and select "install VMware tools"
8 In your terminal mount the cd-rom image. You will get a "read-only" warning.
9 Copy to downloads directory ( the actual file will have numbers in place of 'x','y','z', ... etc.
10 Change to downloads directory and extract and execute
11 Reboot
Enjoy!
Here's how to fix:
sudo apt-get -y remove virtualbox-guest-dkms virtualbox-guest-x11 virtualbox-guest-utils8 In your terminal mount the cd-rom image. You will get a "read-only" warning.
sudo mount /dev/cdrom /cdromCode: Select all
cp /cdrom/VMwareTools-x.y.z-dddddd.tar.gz ~/DownloadsCode: Select all
cd ~/DownloadsCode: Select all
tar -zxf VMwareTools-x.y.z-dddddd.tar.gzCode: Select all
cd VMware-tools-distribCode: Select all
sudo ./VMware-install.plCode: Select all
sudo shutdown -r now
