Crazyradio not enumerating on bus
I got my Crazyflie today, and I'm running into some trouble getting the radio to work. When I plug it in to my Mac (I've tried two machines), the red and green lights both come on and stay on, but no device shows up on the bus. On a Linux box, the LEDs turn back off after half a second, and this shows up in dmesg:
[19727.480558] usb 5-1.1.2: new full-speed USB device number 6 using xhci_hcd
[19727.493471] usb 5-1.1.2: device descriptor read/8, error -75
[19727.606999] usb 5-1.1.2: device descriptor read/8, error -75
[19727.770726] usb 5-1.1.2: new full-speed USB device number 7 using xhci_hcd
[19727.783584] usb 5-1.1.2: device descriptor read/8, error -75
[19727.897158] usb 5-1.1.2: device descriptor read/8, error -75
[19728.059871] usb 5-1.1.2: new full-speed USB device number 8 using xhci_hcd
[19728.072626] usb 5-1.1.2: device descriptor read/8, error -75
[19728.186062] usb 5-1.1.2: device descriptor read/8, error -75
[19728.359000] usb 5-1.1.2: new full-speed USB device number 9 using xhci_hcd
[19728.371706] usb 5-1.1.2: device descriptor read/8, error -75
[19728.485206] usb 5-1.1.2: device descriptor read/8, error -75
[19728.585338] hub 5-1.1:1.0: unable to enumerate USB device on port 2
Is my radio broken? Anything else I could try to troubleshoot?
Re: Crazyradio not enumerating on bus
I'm not the expert on the Crazyradio (Arnaud is) but something is definitely wrong. If the LEDs go off I think it means that the nRF24LU1+ is at least partly working. If I recall correctly the LEDs will go off when it has been enumerated so there might be some hope not having to return it and having to wait for a new one.
If the LEDs does not go off it means that the dongle is not enumerated. I have not seen this problem on Mac previously.
For your Linux log it look like you connected the dongle to a USB3 port, we have seen problems with Linux and USB3. Could you try to connect it to an USB2 port? Do you have a Windows machine lying around to test?
Sure enough, it works on Linux when I connect it to a USB2 root port!
USB3 problems would also explain it not working on the Mac, since I was using a recent Macbook Pro with USB3.
Now to get a controller and learn to fly
Great!
This is actually a bug in the dongle that makes it unable to enumerate on USB3 controllers (at least on Linux and Mac). As we have had problems with USB3 and Linux I was wrongly assuming that it was a Linux problem and we avoided using the USB3 ports
I found where the bug is and am pushing a fix. An update of the firmware will be published later. In the mean time the dongle should be plugged to USB2 ports.
refriedchicken
So, I don't have ready access to USB2 ports and can't use the radio right now. Looking at the repository I see there has been an update to close Issue #2 for USB3 enumeration. How can I go about getting the firmware updated on my dongle?
*** UPDATE ***
I got my hands on a RPi and tried to use that. I can see it showing up as Nordic just like in this thread: http://forum.bitcraze.se/viewtopic.php?f=8&t=102
However still no joy. It blinks the leds once and then goes dark. Running the client on the RPi doesn't show it available as a connection. What logs or anything can I send you to help troubleshoot this.
*** UPDATE ***
The upgrade is in preparation and will arrive soon, sorry about the delay.refriedchicken wrote:So, I don't have ready access to USB2 ports and can't use the radio right now. Looking at the repository I see there has been an update to close Issue #2 for USB3 enumeration. How can I go about getting the firmware updated on my dongle?
Have you tried to run the client as root (with sudo), by default normal users cannot access the USB peripheral.refriedchicken wrote: I got my hands on a RPi and tried to use that. I can see it showing up as Nordic just like in this thread: http://forum.bitcraze.se/viewtopic.php?f=8&t=102
refriedchicken
Yes I did try as root with no luck. I will probably just need to wait for the update then.arnaud wrote:Have you tried to run the client as root (with sudo), by default normal users cannot access the USB peripheral.
No sweat on the upgrade was just thinking of compiling and installing myself if the fix was already committed to the repository.
When running the cfclient from the terminal there should be log messages printed. Could you post them?refriedchicken wrote: However still no joy. It blinks the leds once and then goes dark. Running the client on the RPi doesn't show it available as a connection. What logs or anything can I send you to help troubleshoot this.
As for running on the Pi have a look at these two threads, here and here.
Hello everyone,
I was wondering if the USB3 problem is solved already? If yes how can i update the firmware of the crazy radio when it is not ackknowledged by the system?
for your information i use a late macbook pro. The VM is running on parallels.
Right now both LED's on the Crazyradio are on and wont go out.
thanks for your help
greets
Daniel
greets
Daniel
