Page 1 of 2
Error communicating with the radio
Posted: Sun May 04, 2014 9:29 pm
by heath
Hi, I received a crazyflie yesterday, and I put it together today! When I power it on, all four propellers spin. I think the red light does the appropriate thing and slows down its beeping. Cfclient is installed and my controller can adjusts pitch, roll, etc. but I am failing to connect to the crazyflie. I see several radio options after scanning is complete and clicking on one resullts in this error in the command line:
https://gist.githubusercontent.com/heat ... tfile1.txt
Suggestions on how to go about troubleshooting this?
Re: Error communicating with the radio
Posted: Mon May 05, 2014 7:57 am
by arnaud
Hi, Did you fix the Udev right to access the radio as documented on the wiki:
http://wiki.bitcraze.se/projects:crazyf ... wheezy_etc
A quick way to test is to launch cfclient as root with sudo.
If it does not help can you copy-paste the text in help>about debug tab.
Posted: Mon May 05, 2014 5:35 pm
by heath
Hi arnaud, yeah I went through that as well, and I tested it as root. I'm at company's workplace currently, but when I get back home, I'll paste more information in the gist. Thanks for getting back in touch with me!
Posted: Wed May 07, 2014 3:16 am
by heath
Meant to get to this yesterday, here's the tailed output of dmesg and the error received again when attempting to use the crazyflie radio to connect to the crazyflie, this time with the root user (even though the last user was also in the plugdev group):
Posted: Thu May 08, 2014 7:59 am
by arnaud
Which version of the client and which Linux distribution and version are you using? This looks like an incompatibility of pyusb.
Posted: Thu May 08, 2014 6:43 pm
by heath
ubuntu 14.04
cfclient 2013.4.2
python 2.7.6
pyusb-1.0.0b2
Posted: Tue May 13, 2014 3:51 pm
by heath
An update: still the same errors
Posted: Wed May 14, 2014 5:41 am
by heath
pip install --pre pyusb
Status: flying!
Posted: Wed Dec 31, 2014 3:48 pm
by martijnz
I've got the exact same error message as heath did. I installed the crazyflie client on ubuntu according to
http://wiki.bitcraze.se/projects:crazyf ... stallation.
When trying to connect to the crazyflie, cfclient shows:
Failed to connect on radio://0/0/250K: Error communicating with crazy radio ,it has probably been unplugged!
Exception:write() takes at most 4 arguments (5 given)
My system info:
Ubuntu 14.04.1 LTS
cfclient 2013.4.2
python 2.7.6
pyusb-1.0.0b2
When trying the solution posted by heath:
I get a message that my pyusb is already installed (as shown).
Any ideas how to solve this problem?
Posted: Fri Jan 09, 2015 10:32 am
by marcus
This should be fixed in the latest version of the client (
here's the change). Could you try to either pull it from GitHub or download the
2014.12.1 version. It's caused by a change in the number of parameters between pyusb-1.0.0a2 and pyusb-1.0.0b2, but the new version of the client should work with both versions.
