Hi,all
I was thinking about building a firmware to hold the altitude autonomously only with the aid of the embedded barometer sensor. That is, when I switch on the crazyflie, it flies to the designated altitude and hover on the position. I will not need any PC client or the crazyradio. Is that even possible?
ps: Sorry I am new here and apologize if I ask a stupid question.
Auto altitude control with a barometer
Re: Auto altitude control with a barometer
You might want to take a look at the following links:
http://www.bitcraze.se/2013/10/altitude-hold/
http://wiki.bitcraze.se/projects:crazyf ... itude_hold
http://forum.bitcraze.se/viewtopic.php?f=6&t=523
Hi, derfderf wrote:You might want to take a look at the following links:
Thank u so much!
I have successfully implemented the hover mode using some others' code. Yes, hover mode can be implemented by the PC client using the crazy radio. However, I wonder whether the copter can autonomously hold its altitude without any external radio. With the help of on-chip barometer and embedded processor, is it even possible to construct a closed loop altitude control of itself?
The PC client is only used to set the set point and visualise the sensor data/computed values. All calculations are done on the flie.nkxtlh wrote:However, I wonder whether the copter can autonomously hold its altitude without any external radio. With the help of on-chip barometer and embedded processor, is it even possible to construct a closed loop altitude control of itself?
Thanks for your kindly reminder, I got it.omwdunkley wrote:The PC client is only used to set the set point and visualise the sensor data/computed values. All calculations are done on the flie.nkxtlh wrote:However, I wonder whether the copter can autonomously hold its altitude without any external radio. With the help of on-chip barometer and embedded processor, is it even possible to construct a closed loop altitude control of itself?
