I have few issues with CF
1) Log error. [Battery] No more memory available
2[)Motors] Block too large
but still can run the CF but very hard to control ( poor stability) with joystick in low altitude , could anyone help me ?
STABILITY ISSUE
Re: STABILITY ISSUE
Hi, it looks like an old firmware in the Crazyflie. Can you upgrade to the latest firmware.
There is a ground effect due to turbulence when the copter is close to the ground. Is that what you are seeing?
