D2 - Diode Missing
Posted: Sun Mar 23, 2014 11:19 pm
Reading other posts, I've learned a little about soldering tips, too bad it was after making a mistake from replacing one of the motors. The issue is that I was trying to use a solder sucker to get the solder hole cleaned out. As a result, I managed to unsolder and displace D2 from the PCB, see picture.
Has anyone ever successfully re-attached a surface mounted Diode?. I tried with my soldering iron and didn't have much luck. Someone suggested that I use solder paste and a heat gun, but that doesn't sound like a good solution. Just looking for some repair ideas. M2 doesn't run because of it.
