PROBLEM: Crazyflie Client on OS X Mavericks
I've been using the Crazyflie Client with GUI until the update of OSX Mavericks, there were some problems with Mac Ports and qt4-mac but those seem solved now I installed everything as described on bitbucket ( for py27-pygame I had to use py27-game) but now when I want to start the client python says pygame is not installed. Does anybody have the same problem or a workaround?
absoloodle37
- Member
Re: PROBLEM: Crazyflie Client on OS X Mavericks
Mavericks works fine for me on my Mac (had the Client installed and then updated from Mountain Lion to Mavericks).
Recommend using the Homebrew instructions instead of MacPorts. I could never get the MacPorts install method to work, so I downloaded/installed the full version of Xcode per the instructions and used homebrew.
The latest version of the install page cut off a lot of helpful information for Mac install. Use this older version:
http://wiki.bitcraze.se/projects:crazyf ... 1376354911
Hope this helps.
Hope this helps.
