Page 1 of 2
One of quad engines still running while on battery
Posted: Sat Oct 12, 2013 1:38 pm
by tomdeb
I assambled my new crazyflie quadcopter and maybe I did something wrong (or possibly damaged something). Immediately I connect the battery (without even pushing the power button) engine four starts running . The other three are good, they only slightly move after turning on. What can I do about it
Re: One of quad engines still running while on battery
Posted: Mon Oct 14, 2013 2:46 pm
by tomdeb
Nobody has any idea, what it might be?
Posted: Mon Oct 14, 2013 5:55 pm
by tobias
This thread might solve it.
Posted: Tue Oct 15, 2013 2:57 pm
by tomdeb
I will post pictures of my soldiered board when I get to better camera than iphone. Have you solved the issue in the thread you linked? There is no solution at the end.
Posted: Wed Oct 16, 2013 10:44 am
by tobias
It was actually the MOSFET that was broken (partially shorted) so there is a chance that is the problem with your CF as well but it might also be a shorted soldering. Post some good quality pictures and we can probably tell.
Posted: Wed Oct 16, 2013 2:27 pm
by tomdeb
Ok, and what if the MOSFET is broken... Is there a chance I can get another one, or do I have to buy another one?
Posted: Mon Oct 21, 2013 7:21 am
by tobias
If it is a manufacturing problem you should get a replacement or get it fixed for free. Seeedstudio is responsible for the HW so open a
support case with them in that case.
Posted: Tue Oct 29, 2013 2:51 pm
by tomdeb
Hello this is the best I have managed to get.
Posted: Wed Oct 30, 2013 8:20 am
by tobias
Do you have access to a multimeter? If you have you can try measuring the resistance like described in
this post.
Posted: Thu Oct 31, 2013 3:26 pm
by wtsang02
Hi, I have the same issue on M4. Except its after hard crash. I have unsoldered M4 and just by putting the black and white circuits on M4 holes with battery mounted will will turn on M4 without powering crazyflie. Thanks if any solutions.
