Hi we bought recently 3 crazyflies. And i am wondering is there any easy way(e.g. without coding) how to prevent simultaneous connecting to two of them at the same time? it happens prety often that when one of them is recharging you connect to and then control both of them at the same time. I didn't found anything about two or more crazyflies in FAQ, Help,Tips,Wiki, or Forum so i am asking here. Maybe i am just missing something.
Thank you for reply.
Chobot
Two or more crazy flies
SuperRoach
- Member
Re: Two or more crazy flies
Hm good question.
When using the cfclient, are you using quick connect, or choosing the frequency when you connect?
Just wondering at which point you get collisions
Chobotnatec
I tried both. I don't have them here right now so i can't try it again.
You can use the configuration block that is stored in the Crazyflie to change to a different address for each Crazyflie. Instructions on how to do this is here. Now if you press Quick connect you will only connect to the last one you were connected to.
Chobotnatec
Thanks a lot. sry i just missed it.
Chobot
Chobot
