Failed to change Crazyflie address through Cfclient
chiaerc
Post by chiaerc »
Hi all,
I have been unsuccessfully trying to change the address of my Crazyflies through the "Configure 2.X" tab in the cfclient. What happens is that I can change the address in the Configure 2.X pop-up window, but the "write" button at the bottom is grey and cannot be pressed. The nRF51 and STM firmwares are both up to date. I finally managed to change the address successfully by writing directly to the EEPROM by following the instructions here: https://www.bitcraze.io/documentation/r ... nt/eeprom/
I was wondering if you are also experiencing this issue in Cfclient or if there is something I should do on my side to fix it.
Thank you,
Chiara
Re: Failed to change Crazyflie address through Cfclient
It all sounds a bit strange, I have not seen this.
Did the reset of the EEPROM solve the problem, is the "Write" button enabled now?
