I see this line in multiranger.c :
vTaskDelayUntil(&lastWakeTime, M2T(100));
I decreased it but the maximum frequency I can get seems to be around 15hz only. Meanwhile, in this thread(viewtopic.php?t=4764), I see that the developers were able to get 25hz.
How do I increase the output rate of the multiranger deck further?
How to increase output frequency of multiranger deck?
hamsterasu
Re: How to increase output frequency of multiranger deck?
You need to adjust the VL53L1 timing budget as well. Check zranger2.c for an example. There is a trade-off in accuracy and range though. I suggest you to consult the VL53L1CX datasheet for more details.
You can probably do this in multiranger.c (have not tested)
// Init VL53
if (vl53l1xInit(pdev, I2C1_DEV))
// Configure timing budget
VL53L1_SetDistanceMode(&dev, VL53L1_DISTANCEMODE_MEDIUM);
VL53L1_SetMeasurementTimingBudgetMicroSeconds(&dev, 25000);
DEBUG_PRINT("Init %s sensor [OK]\n", name);
status = true;
else
DEBUG_PRINT("Init %s sensor [FAIL]\n", name);
status = false;
hamsterasu
Thanks! I added the lines
and I was able to get around 20hz now.
