Avoiding the compound statement "with" for the crazyflie
hagel360
Post by hagel360 »
Hi
I would like to be able to start multiple drones in a future product, which is why i want to be able to declare the drones into a variable, and boot them up. But i cannot figure out how to.
I've made two example programs to highlight my issue, the first one doesn't work, the second one does.
scf = SyncCrazyflie(URI, cf=Crazyflie(rw_cache='./cache'))
mr = Multiranger(scf)
while True:
    print(mr.front)
    time.sleep(0.5)
vs.
    with Multiranger(scf) as mr:
        while True:
            print(mr.front)
            time.sleep(0.5)
How can i get the first one to work?
Initialization (works for both programs)
import time
import logging
import cflib.crtp
from cflib.utils.multiranger import Multiranger
URI = 'radio://0/80/2M/E7E7E7E701'
cflib.crtp.init_drivers()
Re: Avoiding the compound statement "with" for the crazyflie
hagel360
Post by hagel360 »
I've read it, but I cannot figure out if it is possible to send two or more different functions to the drones.
For example imagine giving one drone a functions that makes it fly in a random pattern, and another drone following it behind.
As I understood the swarm library, was that it is for using the same function for all drones. But maybe I just need to figure out another way.
The Swarm class is probably not the best solution for you, even if it probably is possible to do it :-)
The key is to understand what "with" is doing, it is called a "context manager" in python, see https://docs.python.org/3/library/stdty ... extmanager).
The "with" is essentially calling two methods when entering and exiting the scope; __enter__(self) and __exit__(self, exc_type, exc_val, exc_tb).
As you can see in the SyncCrazyflie class (https://github.com/bitcraze/crazyflie-l ... #L118-L131) they in turn call open_link() and close_link().
Also see the Multiranger class https://github.com/bitcraze/crazyflie-l ... #L108-L113
Instead of using "with" you can do something like:
scf = SyncCrazyflie(my_uri)
scf.open_link()
mr.start()
# Do your thing
mr.stop()
scf.close_link()
hagel360
Post by hagel360 »
Thank you so much!
This is what i needed.
