wifi_jpeg_streamer issue
Discussions about the AI-deck
sitsaw17
Post by sitsaw17 »
hi
i have been trying to run the wifi_jpeg_streamer examples from the aideck-gap8-examples repo but i get this compiling error:
I have the lastest cf firmware, sdk 3.8.1 and python 3.8.8. Any idea what is causing this?
Re: wifi_jpeg_streamer issue
Post by kimberly »
You should probably update your SDK to at least 4.8, or revert the code back to a commit before any major changes we have done this year.
Mind that the aideck is going through some major changes so that the procedure to flash will change in the coming weeks.
sitsaw17
Post by sitsaw17 »
hi
I managed to find an old version of AI_examples and it works now. thanks
Will the pulp-dronet-v2 for ai-deck also be uppgraded to a newer version of sdk?
Post by kimberly »
Sorry I'm not aware of that if they will update it so you will need to contact them directly on their issue list. If you use the docker images provided by us for the aideck development, it should be easy to switch from different version of the SDK up to 4.8
