LPS Packet loss between anchors
rtkartista09
Post by rtkartista09 »
In a 8 anchor LPS system, there is a more than 20% packet loss between anchor 0-7 and 0-2. I don't understand that conditions that might contribute to such packet loss both on the crazyflie and LPS Sniffer.
Re: LPS Packet loss between anchors
Is it perhaps the distance or some obstacle in between? The radiation pattern around the antenna is also having an effect.
Try to move them closer to see if it makes a difference. How far apart are they?
Try to change the orientation to see if that makes a difference.
You can also increase the transmission power of the radios if you have not already tried that
