is there any way to directly access the values from the TOF sensor in the flow deck to get the actual height above ground and not just the estimated kalman values?
Thank you in advance for your help
Access TOF sensor in Flow Deck
Re: Access TOF sensor in Flow Deck
Yes that is possible. These are part of the 'motion' logging group for the optical flow sensor data and the 'range' logging group for any distance sensor measurements (which you need to look for range.zrange).
