Video Streaming Issues
Posted: Wed Jan 05, 2022 12:36 pm
				Hello!
I have issues with an AI-deck board for video streaming.
My setup:
1. CF stack From Top >> LightHouse Deck + CF + AI Deck + Flow Deck
2. I tested and flash the AIDeck using AI-Deck Workshop Virtual Machine with Olimex ARM-USB-TINY-H
3. I replaced the AI deck greyscale camera to BayerRGB. I tested with test_camera and it provided me img_raw.ppm and image_color.ppm (although it is really greenish color - another issue). This means the camera connection works after I replaced it.
4. I changed the NINA from access point to connect to my router (by changing from menuconfig). It works and I can ping the AI-deck, which I assume the WiFi connection is OK.
Now, the issue is that when I run the video streamer, the viewer says the socket is connected but showing blank image.
I want to attach a snapshot, but I don't know how to do that.
It is similar with what happen in here viewtopic.php?p=22975#p22975
On a side note, I have two identical setup and the video streamer works well on them. I am not sure what happen with this one.
Do you have any suggestions to pinpoint the problem?
My setup:
