Hello.
I am facing a problem when I am using CrazyradioPA to communicate with Crazyflie that sometimes the communication does not work and it drops.
There are many wifi generating devices around and I cannot turn them off.
Is there any way to prevent radio interference and improve the communication situation with Crazyflie?
Best regards
communication problem with using CrazyradioPA
Re: communication problem with using CrazyradioPA
Have you tried to change the channel of your crazyradio? And try out different data bit rates? These are instructions how to do that within cfclient: https://www.bitcraze.io/documentation/r ... figuration
