Unable to Connect to Crazyflie
Posted: Tue Dec 28, 2021 4:51 am
by soso
Hi - I am unable to connect to my Crazyflie. I am using a 2019 Intel Macbook Pro with the Monterey OS.
My Crazyflie is assembled and turns on just fine.
I use a USB to USB-c dongle to plug in my Crazyradio. When I connect it, the green and red LEDS flash quickly then turn off. My Macbook recognizes both the Crazyradio dongle and the Crazyflie when they are plugged in.
In spite of this, my Crazyflie does not appear as an interface to connect to in the cfclient window. Does anybody know what the cause of this may be? I just received all of the equipment recently and do not believe any of them have been used before.
Here is the terminal output when I start the cfclient and search for Crazyflie devices:
Here is what I see in the cfclient window:
Thank you for the help.
Re: Unable to Connect to Crazyflie
Posted: Tue Dec 28, 2021 10:44 am
by arnaud
This is consistent with the behavior when libusb is not installed.
Assuming you are using homebrew, you can install libusb with:
brew install libusb
When the client starts it will automatically scan for Crazyflie which will light-up the RED led on the Crazyradio.
Edit: We have added help on Linux for this kind of problems, I will look at adding a similar help message on mac as well: https://github.com/bitcraze/crazyflie-c ... issues/546
Posted: Tue Dec 28, 2021 7:25 pm
by soso
Thank you so much for the reply! The problem is fixed now.
For future reference for anybody who may need it, I did have a libusb package installed but I had used pip to install it. Perhaps the package installed using pip is the wrong package or dysfunctional somehow. After uninstalling it and installing libusb using Homebrew the issue was fixed.
Posted: Wed Dec 29, 2021 8:56 am
by arnaud
Thanks for the update and for the extra info!
I looked quickly and the PIP libusb package is not libusb, it is a wrapper. Libusb is a C-implemented library.
Though, the package called https://pypi.org/project/libusb-package/ seems to package the libusb lib. This is interesting and should be investigated (it would allow to get rid of the manual libusb install on mac and maybe linux).
