WIFI streamer example
Ozymandias
Post by Ozymandias »
Hiiii
I just started with the wifi streamer example. I wish to connect the crazyflie to my own wifi and send the images to my computer via wifi. I have all the hardware neede, the Olimex debugger and the adapter.....Also GAP_SDK and NINA built with docker both of them. I found the way to run the AP streamer by python, but how can I change the working mode in the aideck to convert it into a wifi streamer???
Re: WIFI streamer example
You will need to reflash the Nina in the current state of the firmware in order to do that: https://www.bitcraze.io/documentation/r ... -streamer/
So with make menuconfig make sure to deselect 'act as access-point' and the add the credentials. I see that the instructions are not super clear on that so I'll update that.
