Frsky Transmitter Button Mapping
Re: Frsky Transmitter Button Mapping
It should be able to do some remapping from the cfclient itself!
See this page: https://www.bitcraze.io/documentation/r ... utdevices/
and this page for instructions: https://www.bitcraze.io/documentation/r ... ut-devices
Let us know if this works out for you
Ah oke! Good that you fixed it! But the crashes are worrysom.
Do you know which version of the cfclient you are using at the moment? Easiest is to copy paste the content of the debug dialog found through 'view' > 'about' > 'debug'
I'm currently not able to confirm this myself so I made a github issue for the crashes you are experiencing: https://github.com/bitcraze/crazyflie-c ... issues/547
