Problems of using AI-deck and SD-card together
Posted: Tue Dec 14, 2021 3:38 am
by WendaZ
Hello AI-deck team,
I plan to use AI-deck and SD-card together to collect some data. However, I think there might be some conflicts between the two decks.
The problem I encountered when using both decks is as follows.
Problem:
When attaching AI-deck and SD-card deck, setting the parameter "usd/logging" onboard doesn't log the data into the SD-card. Sometimes, the drone will restart by a failed assert in "/src/deck/drivers/src/usddeck.c:795", which indicates we cannot write into sd-card file. Sometimes, I can log data, but the LED on the AI-deck will stop blinking.
From the document (
https://www.bitcraze.io/documentation/s ... allocation), the AI-deck and SD-card should be able to use together.
Does anyone have an idea about what would be the conflicts and how can I resolve this problem?
Thanks in advance!
Wenda
Re: Problems of using AI-deck and SD-card together
Posted: Tue Dec 14, 2021 9:13 am
by jonasdn
Hi WendaZ!
So the conflict seem to be the IO_4 port. It is used in the AI deck to reset the GAP8 processor and in the SD deck as chip select for SPI. It seems we are a bit over optimistic in the compatibility matrix.
It _is_ possible to use the SD card deck and the AI deck together, but it seems you need to modify the SD card deck a bit, patching it to use IO1, IO2 or IO3 for CS instead.
And change the driver to use that pin, right now you have in usd_deck.c:
See pull-request for documentation update here:
https://github.com/bitcraze/bitcraze-website/pull/108
Posted: Tue Dec 14, 2021 2:57 pm
by WendaZ
Hi jonasdn,
Thanks for the reply! My question would be how exactly should I patch the SD-card deck?
In the document (
https://www.bitcraze.io/documentation/s ... allocation) it says to connect "via solder bridges or 0 Ohm resistors". Then from my understanding, I should connect either IO1, IO2, or IO3 to IO4 on the SD-card deck and change the driver to that PIN.
Am I correct?
Posted: Tue Dec 14, 2021 4:55 pm
by WendaZ
Hi jonasdn,
I tested the method you provide but I encountered an error.
I connected IO3 to IO4 on the sd-card and modified in the usddeck.c to use DECK_GPIO_IO3 (shown in the attached figure). The sd-card can log data with only sd-card deck is connected to CF.
However, I got an error when I connected both AI-deck and sd-card. The error is as follows.
"DECK_INFO: ERROR: Driver Gpio usage conflicts with a previously enumerated deck driver. No decks will be initialized!".
I tried to disconnect the pin of IO4 to SD-card so that IO4 is only used to AI-deck and IO3 is used to sd-card. However, this error still pops up.
I wonder if you can elaborate your solution for this issue.
Thanks!
Wenda
Posted: Tue Dec 14, 2021 11:49 pm
by WendaZ
One more update.
I desoldered the IO4 and IO3 on the SD-Card. Instead, I connected the IO2 pin on STM to IO4 pin on SD-card and set the firmware to use IO2 for sd-card CS. Meanwhile, the IO4 pin on CF is only connected to the AI-deck.
The figures are attached.
However, the same problem still came up. Please let me know if I did something wrong.
Thanks
Posted: Wed Dec 15, 2021 5:40 am
by jonasdn
Hi WendaZ!
You are doing it correctly it seems, it is just one bit that needs fixing that I did not think of!
The firmware checks at startup that no pins are allocated by multiple drivers, the checks fails, as you see with the message:
DEBUG_PRINT("ERROR: Driver Gpio usage conflicts with a "
"previously enumerated deck driver. No decks will be "
"initialized!\n");
You need to modify usddeck.c, to reflect the change:
static const DeckDriver usd_deck = {
.vid = 0xBC,
.pid = 0x08,
.name = "bcUSD",
.usedGpio = DECK_USING_IO_4,
.usedPeriph = DECK_USING_SPI,
.init = usdInit,
.test = usdTest,
Need to become:
.vid = 0xBC,
.pid = 0x08,
.name = "bcUSD",
.usedGpio = DECK_USING_IO_2,
.init = usdInit,
.test = usdTest,
Posted: Thu Dec 16, 2021 8:30 pm
by WendaZ
Hi jonasdn,
One follow-up. The solution you provided works out.
I provide a small summary as follows for others who wants to use ai-deck and sd-card.
(1) Hardware side:
Disconnect IO4 between CF and sd-card. Connect IO2 (or IO1, IO3) of CF to IO4 on sd-card deck.
(2) Software side:
change line 81 and 1059 of crazyflie firmware to the corresponding pin
(For IO2, change to "#define USD_CS_PIN DECK_GPIO_IO2", ".usedGpio = DECK_USING_IO_2")
With the above changes, I am able to use sd-card and AI-deck together onboard.
Wenda
