anybody build crazyfile firmware on windows success
nomady
Post by nomady »
i have work on this for a few days.use Eclipse CDT + GNU_Tools_ARM_Embedded.i have fixed almost all the problems,now left this one:
when doing link,got this msg :arm-none-eabi/bin/ld.exe: BFD (GNU Tools for ARM Embedded Processors) 2.22.0.20130613 assertion fail /home/build/work/GCC-4-7-build/src/binutils/bfd/elf32-arm.c:12085
and i got a bin file,but size(79k) is bigger then cflie-2013.4.bin(48k).
anybody can help me,thanks anyway.
nomady
Re: anybody build crazyfile firmware on windows success
Post by nomady »
this is my build log:
FireFly.build.log.rar
build log
(2.24 KiB) Downloaded 626 times
internguy
Post by internguy »
Hello!
I seriously haven't compiled on windows. I HIGHLY recommend using the virtual machine provided by bitcraze. After writing my own custom firmware, it only took one makecommand to compile on virtula machine because it already has everything. save your time use VM
nomady
Post by nomady »
thanks for reply.
mebye is the easy way.if i can not solve this problem,i will try to use the vm.
i have no experience on linux.
internguy
Post by internguy »
nomady wrote:thanks for reply.
Don't be afraid to use linux just because you dont have experience.
all you need to do is
1) Download virtualization software
2) download bitcraze virtual machine
3)import virtual machine into your virtualization software
4)boot up your virtual machine
5)go to the crazyflie-fimrware directory
6)open up terminal
7)write "make" witohout quotes press enter
8)it will compile
nomady
Post by nomady »
thank u!
I'm downloading the vm file.
maybe i will love linux...
nomady
Post by nomady »
ok, finally i fix the build process,i got no error,no warning,but at last i got a binary file with size of 79k.
i'm not sure this is right.
the attachment is the build log.
FireFly.build.rar
finally build log
(1.85 KiB) Downloaded 833 times
The 79k size is probably because you build with debug information. Set flag DEBUG=0 to build without it and if you want to build for the bootloader you should set CLOAD=1 as well.
make DEBUG=0 CLOAD=1
nomady
Post by nomady »
tobias wrote:The 79k size is probably because you build with debug information. Set flag DEBUG=0 to build without it and if you want to build for the bootloader you should set CLOAD=1 as well.
u a right!
when i set the optimization level to "Os",i got bin file of 48k.
thank u very much!
by the way,when compile in release mode,the "core_cm3.c" need do some patch:
uint32_t __STREXB(uint8_t value, uint8_t *addr)
   uint32_t result=0;
   //pathed by alex
   //__ASM volatile ("strexb %0, %2, [%1]" : "=r" (result) : "r" (addr), "r" (value) );
   __ASM volatile ("strexb %0, %2, [%1]" : "=&r" (result) : "r" (addr), "r" (value) );
   return(result);
uint32_t __STREXH(uint16_t value, uint16_t *addr)
   uint32_t result=0;
   //patched by alex
   //__ASM volatile ("strexh %0, %2, [%1]" : "=r" (result) : "r" (addr), "r" (value) );
   __ASM volatile ("strexh %0, %2, [%1]" : "=&r" (result) : "r" (addr), "r" (value) );
   return(result);
notice: patch in gcc section
I haven't seen that issue before. Thanks for notifying us.
