You can buy the components from Amazon for around $15 and free shipping with Prime
http://www.amazon.com/Palm-Touchstone-C ... touchstone
http://www.amazon.com/Palm-Computing-Di ... +pre+cover
Here is a proof of concept video:
http://www.youtube.com/watch?v=v1cAh-Rqsco
The receiving coil from the Palm Pre is soldered to a micro-USB cable and then attached to the the bottom of the Crazyflie. Connect the positive and negative leads as shown in the picture and keep the metal shield attached to the back of the coil. Also maintain the positioning of the four small magnets to make sure the coil aligns properly with the Touchstone for efficient power transfer. I lost two of the magnets and hence the difficulty in aligning in the video.
I experimented with connecting it directly to the battery to reduce the weight of the micro-USB connector but could not get it to work. The LiPo battery has a safety circuit built into it and I'm currently trying to figure out what it does. (probably a voltage regulator)
Thoughts? Ideas? Help?
