What is the connector opposite the uUSB on the CF Bolt?
Posted: Wed Nov 03, 2021 6:31 pm
by qubitter
On the Crazyflie Bolt, on the other side of the board from the uUSB, there is a 6-pin female connector, labeled in the datasheet as P3. What is this connector for? Can it be used to connect the Bolt to an external PDB?
Re: What is the connector opposite the uUSB on the CF Bolt?
Posted: Wed Nov 03, 2021 7:08 pm
by qubitter
Also, what is the best method for connecting the Bolt to an external PDB? Ideally there'd be some sort of data link between the two so that I could read power usage and battery information. Is that something that's possible?
Posted: Thu Nov 04, 2021 9:37 am
by tobias
The 6-pin is the SWD program connector.
It is a bit clumsy when used with an external PDB. I would solder to the motor signal wires (the middle pin on the connectors). Remove the XT30 connector and solder smaller wires to the PDB for GND and VBAT. These would power the Bolt and also make it possible for it to measure the voltage.
Posted: Thu Nov 04, 2021 8:54 pm
by qubitter
Tobias,
I'd need to use the motor signal wires to send signals to the motors. Would soldering GND and VBAT where the XT60 connector was provide information to the Bolt about voltage?
Posted: Fri Nov 05, 2021 8:43 am
by tobias
Yes, but keep in mind that the Bolt can take at most 4S.
