Crazyflie Maximum Speed
Barry
Post by Barry »
Dear All,
I am using a bolt and a flow deck to make a drone right now.
My question is what is the maximum speed in x/y that the drone can achieve? I used python API: send_hover_setpoint()
Cheers!
Re: Crazyflie Maximum Speed
The maximum xy velocity the PID controller will accept is 1m/s by default. This is a good limit when using a stock Crazyflie 2.1.
You can change this limit with the parameter posCtlPid.xyVelMax.
Physically, what your drone can achieve will mostly depend of your specific drone (motor/battery/props). The flow deck is unlikely to be the limit there.
