Base path: /home/bitcraze/Desktop/projects/cargo_pocket_ros_ws
Source space: /home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/src
Build space: /home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/build
Devel space: /home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/devel
Install space: /home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/install
#### Running command: "cmake /home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/src -DCATKIN_DEVEL_PREFIX=/home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/devel -DCMAKE_INSTALL_PREFIX=/home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/install -G Unix Makefiles" in "/home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/devel
-- Using CMAKE_PREFIX_PATH: /home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/devel;/opt/ros/noetic
-- This workspace overlays: /home/bitcraze/Desktop/projects/cargo_pocket_ros_ws/devel;/opt/ros/noetic
-- Using PYTHON_EXECUTABLE: /usr/bin/python3
-- Using Debian Python package layout
-- Using empy: /usr/lib/python3/dist-packages/em.py
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/bitcraze/projects/cargo_pocket_ros_ws/build/test_results
-- Forcing gtest/gmock from source, though one was otherwise available.
-- Found gtest sources under '/usr/src/googletest': gtests will be built
-- Found gmock sources under '/usr/src/googletest': gmock will be built
-- Using Python nosetests: /usr/bin/nosetests3
-- catkin 0.8.10
-- BUILD_SHARED_LIBS is on
-- ~~ traversing 1 packages in topological order:
-- ~~ - kernel_mapper_ros
-- +++ processing catkin package: 'kernel_mapper_ros'
-- ==> add_subdirectory(kernel_mapper_ros)
-- Could NOT find crazyflie_driver (missing: crazyflie_driver_DIR)
-- Could not find the required component 'crazyflie_driver'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
CMake Error at /opt/ros/noetic/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
Could not find a package configuration file provided by "crazyflie_driver"
with any of the following names:
crazyflie_driverConfig.cmake
crazyflie_driver-config.cmake
Add the installation prefix of "crazyflie_driver" to CMAKE_PREFIX_PATH or
set "crazyflie_driver_DIR" to a directory containing one of the above
files. If "crazyflie_driver" provides a separate development package or
SDK, be sure it has been installed.
Call Stack (most recent call first):
kernel_mapper_ros/CMakeLists.txt:10 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/bitcraze/projects/cargo_pocket_ros_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/bitcraze/projects/cargo_pocket_ros_ws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
