load system config can't display "saved system config" file.
Posted: Fri Jul 16, 2021 12:32 am
by Yleng002
The .yaml file is in the directory. However, the Crazyflie Client Lighthouse Tab's "Open system config" just can't see the file. Is this the problem with VM or updates?
Thanks
Re: load system config can't display "saved system config" file.
Posted: Fri Jul 16, 2021 8:04 am
by arnaud
This is a bug of the client, I can verify that I have the same problem on my Ubuntu machine. I made a ticket and will start looking at fixing the bug: https://github.com/bitcraze/crazyflie-c ... issues/524. I will write back here when it is fixed.
Posted: Fri Jul 16, 2021 8:51 am
by arnaud
The bug is now fixed. If you launch the "update all" script in the VM you should now be able to load the system config you have previously saved.
Thanks for reporting the problem!
