Third party port - UART packets not as expected
Posted: Mon Jul 12, 2021 3:38 pm
Hi there,
I'm trying to use the lighthouse deck with a third party microcontroller (ESP32). I have been going through the crazieflie source code and have read the relevant README files etc. I'm a little bit stuck at present and would appreciate any help if possible.
What works:
1) I can read the bootloader verison and send the firmware-boot command to the bootloader over I2C. This results in the green LED lighting up and the UART starts to transmit some bytes.
What I'm struggling with:
1) The UART packets I am seeing don't seem to match what I would expect. According to the readme on the fpga repository the deck should be transmitting constant frames of 12 bytes. However when I look at the pulse train using a Saleae logic analyser I can see frames that are 14 bytes long, 35 bytes long and some that are 42 bytes long (the behaviour changes if the senors are covered or unconvered. I have two V1 lighthouses operating in the room in mode b and c so should be using optical sync).
2) The all-1s sync signal is supposed to be 12 bytes long but most of the signals I have captured are only 7 bytes. This is a big problem as I can never sychronise the packet decoder to the start of frame. I notice if I add debug logs to my code that I will get some valid 12-byte 0xFF periods *only* when I cover the sensors to block the lighthouse pulses.
eg:
The timing between consecutive pulse trains seems correct in terms of the Lighthouse system timing of ~8.4ms. But there is too many bytes in each pulse train? The timing between the falling edge of each pulse train decreases when the sensors are uncovered.
The I2C readback tells me that I have bootloader version 2. I am using the master branch of the crazyflie-firmware repo as my reference for the decoder code.
Is there something that I'm missing here? It seems odd that the uart frames I am seeing are not 12 bytes or multiples of same. And the sync frame length seems incorrect. Has anyone seen this before? Maybe my module is damaged somehow?
Thanks!
What works:
eg:
. The timing between consecutive pulse trains seems correct in terms of the Lighthouse system timing of ~8.4ms. But there is too many bytes in each pulse train? The timing between the falling edge of each pulse train decreases when the sensors are uncovered.
Thanks!
