How is asynchronous logging realized?
DarkKnight
Post by DarkKnight »
When I try to learn how to use the logging function in your website(https://www.bitcraze.io/documentation/r ... log_param/). I especially feel interested about asynchronous logging. here are some parts that I feel confused:
Q1: What is the principle behind the log callback function? why asynchronous logging can be achieved in log callback function? Is there a new thread created here?(this is the question that I care most)
Q2:I tried to use LogConfig() class to create two instances since I have too many variables to log and stored them into corresponding csv files. For example, the frequency of logging of both instances is set 100Hz, and the logging time is 10s. Ideally, there should be 1000 data points in each csv file. However, the data points of each file is much less than 1000. is there anything that I do it wrong?
Here is the main function
if __name__ == '__main__':
    cflib.crtp.init_drivers()
    # This will create a new NatNet client
    streamingClient = NatNetClient()
    # Configure the streaming client to call our rigid body handler on the emulator to send data out.
    streamingClient.newFrameListener = receiveNewFrame
    streamingClient.rigidBodyListener = receiveRigidBodyFrame
    with open("IEKF_pose.csv","a",newline='') as csvfile:
        writer = csv.writer(csvfile, delimiter=',')
        writer.writerow(["time","x","y","z","q0","q1","q2","q3"])
    csvfile.close()
    with open("IEKF_stateEstimate.csv","a",newline='') as csvfile:
        writer.writerow(["time","stateEstimate.x","stateEstimate.y","stateEstimate.z","stateEstimate.qw","stateEstimate.qx","stateEstimate.qy","stateEstimate.qz",\
                        "stateEstimate.roll","stateEstimate.pitch", "stateEstimate.yaw"])
    csvfile.close()
    global scf
        scf.cf.param.add_update_callback(group='deck', name='bcFlow2',
                                         cb=param_deck_flow)
        time.sleep(1)
        with open("IEKF_imu.csv","a",newline='') as csvfile:
            writer.writerow(["time","acc.x","acc.y","acc.z","gyro.x","gyro.y","gyro.z","stabilizer.thrust","stabilizer.yaw"])
        csvfile.close()
        logconf = LogConfig(name='Acc_Gyro_Thrust_Yaw', period_in_ms=10)
        logconf.add_variable('acc.x', 'FP16')
        logconf.add_variable('acc.y', 'FP16')
        logconf.add_variable('acc.z', 'FP16')
        logconf.add_variable('gyro.x', 'FP16')
        logconf.add_variable('gyro.y', 'FP16')
        logconf.add_variable('gyro.z', 'FP16')
        logconf.add_variable('stabilizer.thrust', 'FP16')
        logconf.add_variable('stabilizer.yaw', 'FP16')
        scf.cf.log.add_config(logconf)
        logconf.data_received_cb.add_callback(log_IEKF_imu_callback)
        logconf1 = LogConfig(name='stateEstimate', period_in_ms=10)
        logconf1.add_variable('stateEstimate.x', 'FP16')
        logconf1.add_variable('stateEstimate.y', 'FP16')
        logconf1.add_variable('stateEstimate.z', 'FP16')
        logconf1.add_variable('stateEstimate.qw', 'FP16')
        logconf1.add_variable('stateEstimate.qx', 'FP16')
        logconf1.add_variable('stateEstimate.qy', 'FP16')
        logconf1.add_variable('stateEstimate.qz', 'FP16')
        logconf1.add_variable('stateEstimate.roll', 'FP16')
        logconf1.add_variable('stateEstimate.pitch', 'FP16')
        logconf1.add_variable('stateEstimate.yaw', 'FP16')
        scf.cf.log.add_config(logconf1)
        logconf1.data_received_cb.add_callback(log_stateEstimate_callback)
        activate_kalman_estimator(scf.cf)
        activate_high_level_commander(scf.cf)
        reset_estimator(scf.cf)
        # Start up the streaming client now that the callbacks are set up.
        # This will run perpetually, and operate on a separate thread.
        streamingClient.run()
        logconf.start()
        logconf1.start()
        time.sleep(10)
        logconf.stop()
        logconf1.stop()
Here is the log callback function:
def log_IEKF_imu_callback(timestamp, data, logconf):
    #print(data)
    global IEKF_imu
    IEKF_imu[0] = data['acc.x']
    IEKF_imu[1] = data['acc.y']
    IEKF_imu[2] = data['acc.z']
    IEKF_imu[3] = data['gyro.x']
    IEKF_imu[4] = data['gyro.y']
    IEKF_imu[5] = data['gyro.z']
    IEKF_imu[6] = data['stabilizer.thrust']
    IEKF_imu[7] = data['stabilizer.yaw']
    #the following process is used to convert the float data type to Half‑precision floating data type
    hexVal0=hex(IEKF_imu[0])
    hexVal1=hex(IEKF_imu[1])
    hexVal2=hex(IEKF_imu[2])
    hexVal3=hex(IEKF_imu[3])
    hexVal4=hex(IEKF_imu[4])
    hexVal5=hex(IEKF_imu[5])
    hexVal6=hex(IEKF_imu[6])
    hexVal7=hex(IEKF_imu[7])
    y0 = struct.pack("h",int(hexVal0,16))
    y1 = struct.pack("h",int(hexVal1,16))
    y2 = struct.pack("h",int(hexVal2,16))
    y3 = struct.pack("h",int(hexVal3,16))
    y4 = struct.pack("h",int(hexVal4,16))
    y5 = struct.pack("h",int(hexVal5,16))
    y6 = struct.pack("h",int(hexVal6,16))
    y7 = struct.pack("h",int(hexVal7,16))
    IEKF_imu[0] = np.frombuffer(y0,dtype=np.float16)[0]
    IEKF_imu[1] = np.frombuffer(y1,dtype=np.float16)[0]
    IEKF_imu[2] = np.frombuffer(y2,dtype=np.float16)[0]
    IEKF_imu[3] = np.frombuffer(y3,dtype=np.float16)[0]
    IEKF_imu[4] = np.frombuffer(y4,dtype=np.float16)[0]
    IEKF_imu[5] = np.frombuffer(y5,dtype=np.float16)[0]
    IEKF_imu[6] = np.frombuffer(y6,dtype=np.float16)[0]
    IEKF_imu[7] = np.frombuffer(y7,dtype=np.float16)[0]
    print('IEKF_imu:', IEKF_imu)
        writer.writerow([timestamp, IEKF_imu[0], IEKF_imu[1], IEKF_imu[2], IEKF_imu[3], IEKF_imu[4], IEKF_imu[5], IEKF_imu[6], IEKF_imu[7]])
        #writer.writerow([timestamp, IEKF_imu[0], IEKF_imu[1], IEKF_imu[2]])
    csvfile.close()
def log_stateEstimate_callback(timestamp, data, logconf):
    poseStateEstimate[0] = data['stateEstimate.x']
    poseStateEstimate[1] = data['stateEstimate.y']
    poseStateEstimate[2] = data['stateEstimate.z']
    poseStateEstimate[3] = data['stateEstimate.qw']
    poseStateEstimate[4] = data['stateEstimate.qx']
    poseStateEstimate[5] = data['stateEstimate.qy']
    poseStateEstimate[6] = data['stateEstimate.qz']
    poseStateEstimate[7] = data['stateEstimate.roll']
    poseStateEstimate[8] = data['stateEstimate.pitch']
    poseStateEstimate[9] = data['stateEstimate.yaw']
    hexVal0=hex(poseStateEstimate[0])
    hexVal1=hex(poseStateEstimate[1])
    hexVal2=hex(poseStateEstimate[2])
    hexVal3=hex(poseStateEstimate[3])
    hexVal4=hex(poseStateEstimate[4])
    hexVal5=hex(poseStateEstimate[5])
    hexVal6=hex(poseStateEstimate[6])
    hexVal7=hex(poseStateEstimate[7])
    hexVal8=hex(poseStateEstimate[8])
    hexVal9=hex(poseStateEstimate[9])
    y8 = struct.pack("h",int(hexVal8,16))
    y9 = struct.pack("h",int(hexVal9,16))
    poseStateEstimate[0] = np.frombuffer(y0,dtype=np.float16)[0]
    poseStateEstimate[1] = np.frombuffer(y1,dtype=np.float16)[0]
    poseStateEstimate[2] = np.frombuffer(y2,dtype=np.float16)[0]
    poseStateEstimate[3] = np.frombuffer(y3,dtype=np.float16)[0]
    poseStateEstimate[4] = np.frombuffer(y4,dtype=np.float16)[0]
    poseStateEstimate[5] = np.frombuffer(y5,dtype=np.float16)[0]
    poseStateEstimate[6] = np.frombuffer(y6,dtype=np.float16)[0]
    poseStateEstimate[7] = np.frombuffer(y7,dtype=np.float16)[0]
    poseStateEstimate[8] = np.frombuffer(y8,dtype=np.float16)[0]
    poseStateEstimate[9] = np.frombuffer(y9,dtype=np.float16)[0]
    print('poseStateEstimate:', poseStateEstimate)
        writer.writerow([timestamp,poseStateEstimate[0],poseStateEstimate[1],poseStateEstimate[2],poseStateEstimate[3],poseStateEstimate[4],\
                        poseStateEstimate[5],poseStateEstimate[6],poseStateEstimate[7],poseStateEstimate[8],poseStateEstimate[9]])
    csvfile.close()
jonasdn
Re: How is asynchronous logging realized?
Post by jonasdn »
Hi DarkKnight!
Q1:
There is a thread for incoming packet that sends logging data to the correct handler/callback.
https://github.com/bitcraze/crazyflie-l ... .py#L357:7
Q2
I modified your example to get it to run:
import time
import struct
import cflib
import csv
from cflib.utils import uri_helper
URI = uri_helper.uri_from_env(default='radio://0/56/2M/E7E7E7E7E7')
    #print(data)
    IEKF_imu = [0.0] * 8
    # hexVal0=hex(IEKF_imu[0])
    # hexVal1=hex(IEKF_imu[1])
    # hexVal2=hex(IEKF_imu[2])
    # hexVal3=hex(IEKF_imu[3])
    # hexVal4=hex(IEKF_imu[4])
    # hexVal5=hex(IEKF_imu[5])
    # hexVal6=hex(IEKF_imu[6])
    # hexVal7=hex(IEKF_imu[7])
    # y0 = struct.pack("h",int(hexVal0,16))
    # y1 = struct.pack("h",int(hexVal1,16))
    # y2 = struct.pack("h",int(hexVal2,16))
    # y3 = struct.pack("h",int(hexVal3,16))
    # y4 = struct.pack("h",int(hexVal4,16))
    # y5 = struct.pack("h",int(hexVal5,16))
    # y6 = struct.pack("h",int(hexVal6,16))
    # y7 = struct.pack("h",int(hexVal7,16))
    # IEKF_imu[0] = np.frombuffer(y0,dtype=np.float16)[0]
    # IEKF_imu[1] = np.frombuffer(y1,dtype=np.float16)[0]
    # IEKF_imu[2] = np.frombuffer(y2,dtype=np.float16)[0]
    # IEKF_imu[3] = np.frombuffer(y3,dtype=np.float16)[0]
    # IEKF_imu[4] = np.frombuffer(y4,dtype=np.float16)[0]
    # IEKF_imu[5] = np.frombuffer(y5,dtype=np.float16)[0]
    # IEKF_imu[6] = np.frombuffer(y6,dtype=np.float16)[0]
    # IEKF_imu[7] = np.frombuffer(y7,dtype=np.float16)[0]
    csvfile.close()
    poseStateEstimate = [0] * 10
    # hexVal0=hex(poseStateEstimate[0])
    # hexVal1=hex(poseStateEstimate[1])
    # hexVal2=hex(poseStateEstimate[2])
    # hexVal3=hex(poseStateEstimate[3])
    # hexVal4=hex(poseStateEstimate[4])
    # hexVal5=hex(poseStateEstimate[5])
    # hexVal6=hex(poseStateEstimate[6])
    # hexVal7=hex(poseStateEstimate[7])
    # hexVal8=hex(poseStateEstimate[8])
    # hexVal9=hex(poseStateEstimate[9])
    # y8 = struct.pack("h",int(hexVal8,16))
    # y9 = struct.pack("h",int(hexVal9,16))
    # poseStateEstimate[0] = np.frombuffer(y0,dtype=np.float16)[0]
    # poseStateEstimate[1] = np.frombuffer(y1,dtype=np.float16)[0]
    # poseStateEstimate[2] = np.frombuffer(y2,dtype=np.float16)[0]
    # poseStateEstimate[3] = np.frombuffer(y3,dtype=np.float16)[0]
    # poseStateEstimate[4] = np.frombuffer(y4,dtype=np.float16)[0]
    # poseStateEstimate[5] = np.frombuffer(y5,dtype=np.float16)[0]
    # poseStateEstimate[6] = np.frombuffer(y6,dtype=np.float16)[0]
    # poseStateEstimate[7] = np.frombuffer(y7,dtype=np.float16)[0]
    # poseStateEstimate[8] = np.frombuffer(y8,dtype=np.float16)[0]
    # poseStateEstimate[9] = np.frombuffer(y9,dtype=np.float16)[0]
    # streamingClient = NatNetClient()
    # # Configure the streaming client to call our rigid body handler on the emulator to send data out.
    # streamingClient.newFrameListener = receiveNewFrame
    # streamingClient.rigidBodyListener = receiveRigidBodyFrame
    global scf
        csvfile.close()
        # streamingClient.run()
        logconf.start()
        logconf1.start()
        time.sleep(10)
        logconf.stop()
        logconf1.stop()
And after running this:
$ wc -l IEKF_imu.csv
1011 IEKF_imu.csv
$ wc -l IEKF_stateEstimate.csv
1013 IEKF_stateEstimate.csv
So it seems wer can get and write in 100hz, maybe you have something that takes a lot of CPU in your handlers if this does not work for you?
DarkKnight
Hey,Jonasdn,
Thank you for your reply. For Q1: is that means if I use LogConfig() class to create two instances and there are two corresponding callback functions. Then two threads are also created?
For Q2, I also tried your modified example, but the data and number of data are both wrong(attached here). What do you mean for the" I have something that takes a lot of CPU in my handlers"?
(22.36 KiB) Downloaded 492 times
IEKF_imu.csv
(28.92 KiB) Downloaded 431 times
jonasdn
Post by jonasdn »
Q1: No there is only one thread that can call multiple callbacks.
Q2: If you have something that takes a lot of CPU in your loop then you might miss some packets.
Are you in a VM, then the additional radio latency it might be hard for you to receive all packets, would you have the option to try without a VM?
DarkKnight
Yes. I am using a VM, and I believe that is the reason why the data is missing. I have done some tests without a VM, your modified example works well and the data quality is perfect.
Thank you very much!
