I have a few crazyflies for my lab, and one of them (the first one assembled) has been through a lot of crashes and as a result has had some casualties, including the On/Off button that at some point broke off.
A few days ago, the power cable got loose and so I did a little bit of soldering and replaced the power cable on the crazyflie with a JST cable. Now when I plug in a battery, only the M3 Led turns on.
Could it be that I have burnt the processor (or sth else on the board), or could the crazyflie simply need a firmware update. And if so, is there a way to bootload a Crazyflie that doesn't have an On/Off button?
Cheers!
