I wish to check the possibilities of programming crazyflie.
For example, let the copter carry a table tennis ball, use a Kinect camera to track is position in space... is it possible to program and control the copter to fly a pre-planned route?
Thinking of using the pykinect package:
https://pypi.python.org/pypi/pykinect/1.0
Ultimately, would be really crazy if I could let it balance a pole, like Dr. Raffaello D'Andrea did in this video with larger quadcopters:
http://www.youtube.com/watch?v=w2itwFJCgFQ
Any thoughts or experiences with similar setup would be greatly appreciated! Thanks.
- Thinkfly
crazyflie with pykinect
Re: crazyflie with pykinect
This sounds exiting, it would be great to see it implemented
As for controlling the Crazyflie it's easy if you use the Python API. It's just a couple of lines of code to connect to the Crazyflie and send control commands. Have a look at this old thread to see a short example. The naming of the functions in the API has changed slightly but the principle is the same.
Marcus thanks for the reply
