What it's needed to compile the binary, then flash it on the Crazyflie using the bootloader of the cfclient??
I already have the firmware but I can not run the Makefile.
I have windows 7 and Visual Studio 2012.
I already installed the cfclient from code using python and PtQ and is working.
Thanks.
[SOLVED] How to compile the binary to flash on the crazyflie
Re: How to compile the binary to flash on the crazyflie
As a first step I would try the Virtual Machine. It has everything pre-installed and should get you going quickly.
Thanks!!, it works fine.
