I have a question about the set up of the LPS system.
From the official document, the size of the flight area was set up by 2.95*6.3*2.65 meters with eight loco positioning anchors.
Is it possible to set up a bigger area by putting the anchors further away from each other? Is there a maximum size of the flight area?
Also, if we set up a bigger area, will it results in a worse accuracy than +-10 cm?
Thank you.
Sincerely,
Yu-Hsiang
LPS setup
Re: LPS setup
Yes it is possible to set up a larger system. The default settings reach 2-4 meters so if you set up a larger system you probably have to increase the transmission power in the anchors (and the crazyflie if you are using TWR).
You can read about low level config of the anchors here: https://www.bitcraze.io/documentation/r ... el-config/
To increase the TX power, set the desired power and "Force TX power"=true
To increase the TX power in the Crazyflie, recompile the firmware with "CFLAGS += -DLPS_FULL_TX_POWER" in your config.mk file
Increased TX power will probably work up to around 10 meters. If you want to go even larger it is possible to use a longer preamble, there is functionality for this but it is fairly experimental.
We use the Decawave DW1000 chips on the decks and anchors and the best source of detailed information is the data sheets from decawave.
Re: LPS setup
Hi Kristoffer,
Thank you for your reply.
I am planning to fly multiple Crazyflies using TDoA2 mode. In that case, do I need to increase the TX power in the Crazyflies, or just the anchors?
If I would like to follow the recommendation setting which is 2.95*6.3*2.65 meters with eight loco positioning anchors, do I need to recompile the Crazyflie firmware or increase the TX power of the anchors?
Also, I just read the article about the low-level config of the anchors. It mentioned that we need to connect to either Linux or OSX terminal. Does it not support the Windows system? And how do we exactly set up the desired power of the anchors? I saw this line CONFIG: TX power setting: 1F1F1F1F in the menu and configuration section, what does 1F1F1F1F mean here?
Sincerely,
Yu-Hsiang
Sincerely,
Yu-Hsiang
Re: LPS setup
Hi Yu-Hsiang!
I'm sorry the documentation is lacking in this area.
A side note: You may want to consider to use TDoA3 as it is more robust.
When you have connected to the anchor you should get something like this:
Press 'p' to change the TX power
Press '9' for maximum power
Press 'f' to set "ForceTxPower"
The result should be
The '1F1F1F1F' is the value of the register set in the chip, it is not very human friendly unfortunately
No, the anchors is enough.I am planning to fly multiple Crazyflies using TDoA2 mode. In that case, do I need to increase the TX power in the Crazyflies, or just the anchors?
No, recompiling the Crazyflie firmware is only necessary to increase the TX power of the Crazyflie.If I would like to follow the recommendation setting which is 2.95*6.3*2.65 meters with eight loco positioning anchors, do I need to recompile the Crazyflie firmware or increase the TX power of the anchors?
Windows should work as well, all you need is a terminal program that can connect to a serial port (USB in this case)Also, I just read the article about the low-level config of the anchors. It mentioned that we need to connect to either Linux or OSX terminal. Does it not support the Windows system? And how do we exactly set up the desired power of the anchors? I saw this line CONFIG: TX power setting: 1F1F1F1F in the menu and configuration section, what does 1F1F1F1F mean here?
SYSTEM : CPU-ID: 3e002f001757344730333020
TEST : Initializing pressure sensor ... [OK]
TEST : Pressure sensor self-test ... [OK]
TEST : EEPROM self-test ... [OK]
CONFIG : EEPROM configuration read and verified
TEST : Initialize UWB ... [OK]
CONFIG : Address is 0x0
CONFIG : Mode is TWR Anchor
CONFIG : Tag mode anchor list (0):
CONFIG : Anchor position enabled: true
CONFIG : Anchor position: -3.550000 0.000000 0.150000
CONFIG : SmartPower enabled: False
CONFIG : Force TX power: True
CONFIG : TX power setting: 1F1F1F1F
CONFIG : Bitrate: normal
CONFIG : Preamble: normal
SYSTEM : Node started ...
SYSTEM : Press 'h' for help.
Power menu
0-9 - to set ForceTxPower power (from 3.5dB to 33.5dB)
f - for ForceTxPower
s - for SmartPower
Setting txpower to: 0x1F1F1F1F = 33.5dB
EEPROM configuration changed, restart for it to take effect!
Setting ForceTxPower
Re: LPS setup
So, if I wanna increase the TX power in Crazyflie and recompile with the config.mk, should I use the command make cload or make clean? Also, in what circumstance do I need to increase the TX power in Crazyflie? Flying with TDoA2 mode or TDoA3 mode or both?
Best,
Yu-Hsiang
Best,
Yu-Hsiang
Re: LPS setup
This will clean, build and flash to the Crazyflie
The only time the CF transmits in TDoA is when you change the mode (TWR, TDoA2 or TDoA3) of the system, for this increased TX power will help.
make clean
make
make cload
In the TDoA modes, the Crazyflie is only listening and not transmitting (with the UWB radio) so increased TX power on the CF is not that usefulAlso, in what circumstance do I need to increase the TX power in Crazyflie? Flying with TDoA2 mode or TDoA3 mode or both?
