Last version of firmware that reboot.py works?
cafeciaojoe
Post by cafeciaojoe »
I am trying to get the PowerSwitch Module to work. I am using cflib 0.1.12.1 and the 2020.09 firmware.
I have modified the line from reboot.py slightly, see below:
uri = 'radio://0/80/2M/E7E7E7E7E7'
PowerSwitch(uri).stm_power_cycle()
I get the same attribute error as user aqqz in the thread below.
AttributeError: 'NoneType' object has no attribute 'ack'
In the thread (viewtopic.php?f=2&t=4552) it was stated that:
kimberly wrote: ↑Tue Dec 01, 2020 3:23 pm
So I tried it with firmware 2019.01 and cflib version 0.1.11 (which is the last version feature will work on). It works fine for me.
I attempted to try this with a cf on the 2019.01 firmware but could not seem to even get the firmware to compile? cloned folder to the same directory level as cflib and the client
git clone --recursive https://github.com/bitcraze/crazyflie-firmware.git --branch 2019.01 "crazyflie-firmware-2019.01"
only to get the following message when running 'make all'
make: python2: No such file or directory
make: *** [check_submodules] Error 1
PhD Student
RMIT University
School of Design
http://www.cafeciaojoe.com
Re: Last version of firmware that reboot.py works?
The cflib has removed all instances of python2 in the latest releases, and Ubuntu 20.04 doesnt have python2 anymore. But when I tried the old versions, that was just to indicate the oldest version that this will work on, not as an instruction that you should downgrade it.
I think you first need to make an instance of the powerswitch class and then use that. Like this:
ps = PowerSwitch(uri)
ps.stm_power_cycle()
Let us know if this works and if not, I'll try it myself too.
Just an update on this, I seem to have recreated the error too:
python3 reboot.py radio://0/10/2M/E7E7E7E7E7
with error:
  File "reboot.py", line 33, in <module>
    PowerSwitch(sys.argv[1]).stm_power_cycle()
  File "/home/kimberly/Development/Bitcraze/Python/crazyflie-lib-python/cflib/utils/power_switch.py", line 63, in stm_power_cycle
    self.stm_power_down()
  File "/home/kimberly/Development/Bitcraze/Python/crazyflie-lib-python/cflib/utils/power_switch.py", line 54, in stm_power_down
    self._send(self.BOOTLOADER_CMD_SYSOFF)
  File "/home/kimberly/Development/Bitcraze/Python/crazyflie-lib-python/cflib/utils/power_switch.py", line 79, in _send
    if res.ack:
This worked for me before so we will check out how can be fixed. We are planning a release this week so try again once it is available.
cafeciaojoe
No problem, will wait for the release, and report back here, thanks for updating!
PhD Student
RMIT University
School of Design
The release is out! So it should be fixed now. Can you try again?
cafeciaojoe
[solved] Last version of firmware that reboot.py works?
this works great thanks!
PhD Student
RMIT University
School of Design
