TDOA2_decoder.py
Posted: Fri Nov 27, 2020 9:52 am
by HSIAOJH
I'm the beginner of Python but can run sniffer_binary.py to dump the log over shell, seen attachment.
The next is to decoder it for better understanding TDOA2 protocol ….
However, I don't know exactly and fail to use TDOA2_Decoder.py to decode these packages. The shell hangs and is likely waiting for input... see attachment.
Shell_TDOA2 Decoder.PNG (9.55 KiB) Viewed 3791 times
Do I need to change any code? Any guidelines, instructions or kind help can be from support team?
Thanks a lot!
JH
Re: TDOA2_decoder.py
Posted: Mon Nov 30, 2020 11:01 am
by kristoffer
The general idea is to pipe the output from the sniffer into the decoder
Assuming you are using a unix shell you should do something like this
./tools/sniffer/sniffer_binary.py | ./tools/sniffer/tdoa2_decoder.py
Posted: Tue Dec 01, 2020 7:18 am
by HSIAOJH
I'm not using unix shell. how do I get this script running with python?
Posted: Tue Dec 01, 2020 7:54 am
by kristoffer
I'm not a windows expert, but I think you can pipe in windows as well.
I don't have a windows machine to test on, but try something like this:
from your normal command prompt (not in python), cd to the root of the repository
Then run the scripts
python tools\sniffer\sniffer_binary.py | python tools\sniffer\tdoa2_decoder.py
Re: TDOA2_decoder.py [Resolved]
Posted: Tue Dec 01, 2020 9:26 am
by HSIAOJH
Thanks! It works now!
