TDOA2_decoder.py
HSIAOJH
TDOA2_decoder.py
Post by HSIAOJH »
I'm the beginner of Python but can run sniffer_binary.py to dump the log over shell, seen attachment.
The next is to decoder it for better understanding TDOA2 protocol ….
However, I don't know exactly and fail to use TDOA2_Decoder.py to decode these packages. The shell hangs and is likely waiting for input... see attachment.
Shell_TDOA2 Decoder.PNG (9.55 KiB) Viewed 1654 times
Do I need to change any code? Any guidelines, instructions or kind help can be from support team?
Thanks a lot!
JH
Re: TDOA2_decoder.py
Post by kristoffer »
The general idea is to pipe the output from the sniffer into the decoder
Assuming you are using a unix shell you should do something like this
./tools/sniffer/sniffer_binary.py | ./tools/sniffer/tdoa2_decoder.py
HSIAOJH
Post by HSIAOJH »
I'm not using unix shell. how do I get this script running with python?
I'm not a windows expert, but I think you can pipe in windows as well.
I don't have a windows machine to test on, but try something like this:
from your normal command prompt (not in python), cd to the root of the repository
Then run the scripts
python tools\sniffer\sniffer_binary.py | python tools\sniffer\tdoa2_decoder.py
HSIAOJH
Re: TDOA2_decoder.py [Resolved]
Post by HSIAOJH »
Thanks! It works now!
