Taranis with CFclient issue [solved]
Posted: Tue Nov 24, 2020 7:45 am
I would like to use my Taranis X9D as a flight controller for manual flying and I am following this guide: https://wiki.bitcraze.io/misc:hacks:taranis
My problem is that Crazyflie PC client doesn´t seem to recognize the controller even though it is visible in device manager as seen in the picture:
(PS4 is not connected but it still shows as a only input device)
Manual flying with PS4 controller is working fine. Can you give any guide how I should investigate this connecting problem?
Let me know if this post is more fitting for some other channel and I will change it.
