import argparse
import logging
import math
import time
import numpy as np
import cv2 as cv
import cflib.crtp
from cflib.crazyflie.log import LogConfig
from cflib.crazyflie.swarm import CachedCfFactory
from cflib.crazyflie.swarm import Swarm
from cflib.crazyflie.syncLogger import SyncLogger
from cflib.crazyflie.mem import LighthouseBsGeometry
from cflib.crazyflie.mem import MemoryElement
# TODO get this list from a configuration file (maybe CSV?)
URI1 = 'radio://0/70/2M/E7E7E7E701'
URI2 = 'radio://0/70/2M/E7E7E7E702'
URI3 = 'radio://0/70/2M/E7E7E7E703'
uris = {
URI1,
URI2,
URI3,
def wait_for_param_download(scf):
while not scf.cf.param.is_updated:
time.sleep(1.0)
print('Parameters downloaded for', scf.cf.link_uri)
def read_sensors(scf):
logs = {
'lighthouse.angle0x': [0, 0, 0],
'lighthouse.angle0y': [0, 0, 1],
'lighthouse.angle0x_1': [0, 1, 0],
'lighthouse.angle0y_1': [0, 1, 1],
'lighthouse.angle0x_2': [0, 2, 0],
'lighthouse.angle0y_2': [0, 2, 1],
'lighthouse.angle0x_3': [0, 3, 0],
'lighthouse.angle0y_3': [0, 3, 1],
'lighthouse.angle1x': [1, 0, 0],
'lighthouse.angle1y': [1, 0, 1],
'lighthouse.angle1x_1': [1, 1, 0],
'lighthouse.angle1y_1': [1, 1, 1],
'lighthouse.angle1x_2': [1, 2, 0],
'lighthouse.angle1y_2': [1, 2, 1],
'lighthouse.angle1x_3': [1, 3, 0],
'lighthouse.angle1y_3': [1, 3, 1],
storage = {}
confs = [
LogConfig(name='lh1', period_in_ms=10),
LogConfig(name='lh2', period_in_ms=10),
LogConfig(name='lh3', period_in_ms=10),
# Set up log blocks
count = 0
floats_per_block = 6
for name in logs.keys():
confs[int(count / floats_per_block)].add_variable(name, 'float')
count += 1
# Read log data
with SyncLogger(scf, confs) as logger:
end_time = time.time() + 1.0
for log_entry in logger:
data = log_entry[1]
for log_name in data:
if not log_name in storage:
storage[log_name] = []
storage[log_name].append(data[log_name])
if time.time() > end_time:
break
# Average sensor data
sensor_sweeps = np.zeros([2, 4, 2])
for log_name, data in storage.items():
sensor_info = logs[log_name]
sensor_sweeps[sensor_info[0]][sensor_info[1]][sensor_info[2]] = np.average(data)
return sensor_sweeps
# Create a hash from a vector with sensor ids
def hash_sensor_order(order):
hash = 0
for i in range(4):
hash += order[i] * 4 ** i
return hash
def estimate_yaw_to_base_station(sensor_sweeps):
direction = {
hash_sensor_order([2, 0, 1, 3]): math.radians(0),
hash_sensor_order([2, 0, 3, 1]): math.radians(25),
hash_sensor_order([2, 3, 0, 1]): math.radians(65),
hash_sensor_order([3, 2, 0, 1]): math.radians(90),
hash_sensor_order([3, 2, 1, 0]): math.radians(115),
hash_sensor_order([3, 1, 2, 0]): math.radians(155),
hash_sensor_order([1, 3, 2, 0]): math.radians(180),
hash_sensor_order([1, 3, 0, 2]): math.radians(205),
hash_sensor_order([1, 0, 3, 2]): math.radians(245),
hash_sensor_order([0, 1, 3, 2]): math.radians(270),
hash_sensor_order([0, 1, 2, 3]): math.radians(295),
hash_sensor_order([0, 2, 1, 3]): math.radians(335),
# Assume bs is faicing slighly downwards and fairly horizontal
# Sort sensors in the order they are hit by the horizontal sweep
# and use the order to figure out roughly the direction to the
# base station
sweeps_x = {0: sensor_sweeps[0][0], 1: sensor_sweeps[1][0], 2: sensor_sweeps[2][0], 3: sensor_sweeps[3][0]}
ordered_map = {k: v for k, v in sorted(sweeps_x.items(), key=lambda item: item[1])}
sensor_order = list(ordered_map.keys())
# The base station is roughly in this direction, in CF (world) coordinates
return direction[hash_sensor_order(sensor_order)]
def generate_initial_estimate(bs_direction):
# Base station height
bs_h = 2
# Distance to base station along the floor
bs_fd = 3
bs_dist = math.sqrt(bs_h ** 2 + bs_fd ** 2)
elevation = math.atan2(bs_h, bs_fd)
# Initial position of the CF in camera coordinate system, open cv style
tvec_start = np.array([0, 0, bs_dist])
# Calculate rotation matrix
d_c = math.cos(-bs_direction + math.pi)
d_s = math.sin(-bs_direction + math.pi)
R_rot_y = np.array([
[d_c, 0.0, d_s],
[0.0, 1.0, 0.0],
[-d_s, 0.0, d_c],
e_c = math.cos(elevation)
e_s = math.sin(elevation)
R_rot_x = np.array([
[1.0, 0.0, 0.0],
[0.0, e_c, -e_s],
[0.0, e_s, e_c],
R = np.dot(R_rot_x, R_rot_y)
rvec_start, _ = cv.Rodrigues(R)
return rvec_start, tvec_start
def calc_initial_estimate(sensor_sweeps):
yaw = estimate_yaw_to_base_station(sensor_sweeps)
return generate_initial_estimate(yaw)
def cam_to_world(rvec_c, tvec_c):
R_c, _ = cv.Rodrigues(rvec_c)
R_w = np.linalg.inv(R_c)
tvec_w = -np.matmul(R_w, tvec_c)
return R_w, tvec_w
def opencv_to_cf(R_cv, t_cv):
R_opencv_to_cf = np.array([
[0.0, 0.0, 1.0],
[-1.0, 0.0, 0.0],
[0.0, -1.0, 0.0],
R_cf_to_opencv = np.array([
[0.0, -1.0, 0.0],
[0.0, 0.0, -1.0],
[1.0, 0.0, 0.0],
t_cf = np.dot(R_opencv_to_cf, t_cv)
R_cf = np.dot(R_opencv_to_cf, np.dot(R_cv, R_cf_to_opencv))
return R_cf, t_cf
def estimate_geometry(sensor_sweeps, rvec_start, tvec_start):
sensor_distance_width = 0.015
sensor_distance_length = 0.03
# Sensor positions in world coordinates, open cv style
lighthouse_3d = np.float32(
[-sensor_distance_width / 2, 0, -sensor_distance_length / 2],
[sensor_distance_width / 2, 0, -sensor_distance_length / 2],
[-sensor_distance_width / 2, 0, sensor_distance_length / 2],
[sensor_distance_width / 2, 0, sensor_distance_length / 2]
# Sensors as seen by the "camera"
lighthouse_image_projection = np.float32(
[-math.tan(sensor_sweeps[0][0]), -math.tan(sensor_sweeps[0][1])],
[-math.tan(sensor_sweeps[1][0]), -math.tan(sensor_sweeps[1][1])],
[-math.tan(sensor_sweeps[2][0]), -math.tan(sensor_sweeps[2][1])],
[-math.tan(sensor_sweeps[3][0]), -math.tan(sensor_sweeps[3][1])]
# Camera matrix
K = np.float64(
[1.0, 0.0, 0.0],
[0.0, 1.0, 0.0],
[0.0, 0.0, 1.0]
dist_coef = np.zeros(4)
_ret, rvec_est, tvec_est = cv.solvePnP(
lighthouse_3d,
lighthouse_image_projection,
K,
dist_coef,
flags=cv.SOLVEPNP_ITERATIVE,
rvec=rvec_start,
tvec=tvec_start,
useExtrinsicGuess=True)
if not _ret:
raise Exception("No solution found")
Rw_ocv, Tw_ocv = cam_to_world(rvec_est, tvec_est)
return Rw_ocv, Tw_ocv
def print_geo(rotation_cf, position_cf):
print("{.origin = {", end='')
for i in position_cf:
print("{:0.6f}, ".format(i), end='')
print("}, .mat = {", end='')
for i in rotation_cf:
print("{", end='')
for j in i:
print("{:0.6f}, ".format(j), end='')
print("}, ", end='')
print("}},")
class WriteMem:
def __init__(self, scf, bs1, bs2):
self.data_written = False
mems = scf.cf.mem.get_mems(MemoryElement.TYPE_LH)
count = len(mems)
if count != 1:
raise Exception('Unexpected nr of memories found:', count)
mems[0].geometry_data = [bs1, bs2]
mems[0].write_data(self._data_written)
while not self.data_written:
time.sleep(1)
def _data_written(self, mem, addr):
self.data_written = True
print('Data written')
def upload_geo_data(scf, geometries):
bs1 = LighthouseBsGeometry()
bs1.rotation_matrix = geometries[0][0]
bs1.origin = geometries[0][1]
bs2 = LighthouseBsGeometry()
bs2.rotation_matrix = geometries[1][0]
bs2.origin = geometries[1][1]
WriteMem(scf, bs1, bs2)
def sanity_check(position_cf):
max_pos = 10.0
for coord in position_cf:
if (abs(coord) > max_pos):
return False
return True
def calculate_lh_bs_data(scf):
print("Reading sensor data...")
sensor_sweeps_all = read_sensors(scf)
print("Estimating position of base stations...")
geometries = []
for bs in range(2):
sensor_sweeps = sensor_sweeps_all[bs]
rvec_start, tvec_start = calc_initial_estimate(sensor_sweeps)
geometry = estimate_geometry(sensor_sweeps, rvec_start, tvec_start)
rotation_cf, position_cf = opencv_to_cf(geometry[0], geometry[1])
if not sanity_check(position_cf):
position_cf = [0, 0, 0]
rotation_cf = [[1, 0, 0], [0, 1, 0], [0, 0, 1]]
print("Could not find valid solution for base station ", bs)
geometries.append([rotation_cf, position_cf])
# Do we need this to be optional?
if args.write:
print("Uploading geo data")
if __name__ == '__main__':
parser = argparse.ArgumentParser()
parser.add_argument("--write", help="upload the calculated geo data to the Crazflie", action="store_true")
args = parser.parse_args()
factory = CachedCfFactory(rw_cache='./cache')
with Swarm(uris, factory=factory) as swarm:
# The current values of all parameters are downloaded as a part of the
# connections sequence. Since this clogs up connection and takes a while
# we do it in this script rather than the flight script
print('Waiting for parameters to be downloaded...')
swarm.parallel(wait_for_param_download)
# Here we do the actual LH geometry calculation
warm.parallel(calculate_lh_bs_data)
So here are my questions:
- What am I doing wrong here?
- Is this even a good idea in the first place?
