Is there a way to modify the basiclogSync.py example to let the quadcopter log more data (12 states variables)
[SOLVED] Data Logging
Re: Data Logging
There is a limitation on the number of log variables in one log block (due to the radio packet size), but you can define multiple log blocks and pass an array of log blocks to the SyncLogger in one go
lg_1 = LogConfig(name='first', period_in_ms=50)
# ... more code to define the log block
lg_2 = LogConfig(name='second', period_in_ms=50)
with SyncCrazyflie('usb://0') as scf:
with SyncLogger(scf, [lg_1, lg_2]) as logger:
# Do stuff with the log data
- Member
Re: Data Logging
Hi Kris,
I tried your code but it shows error of list object has no attribute of 'default_fetch_as'. Can you show me what I might have done wrongly please?
import logging
import time
import cflib.crtp
import numpy as np
URI = 'radio://0/80/2M'
if __name__ == '__main__':
lg1 = LogConfig(name='Stabilizer', period_in_ms=10)
#lg1.add_variable('stabilizer.roll', 'float')
#lg1.add_variable('stabilizer.pitch', 'float')
#lg1.add_variable('stabilizer.yaw', 'float')
#lg1.add_variable('stabilizer.thrust','float')
lg1.add_variable('stateEstimate.z','float')
lg1.add_variable('stateEstimate.vz','float')
lg1.add_variable('stateEstimate.roll', 'float')
lg1.add_variable('stateEstimate.pitch', 'float')
lg1.add_variable('stateEstimate.yaw', 'float')
lg2 = LogConfig(name='Stabilizer', period_in_ms=10)
lg2.add_variable('stateEstimate.x','float')
lg2.add_variable('stateEstimate.vx','float')
lg2.add_variable('stateEstimate.y', 'float')
lg2.add_variable('stateEstimate.vy', 'float')
lg2.add_variable('stateEstimateZ.quat', 'uint32_t')
cf = Crazyflie(rw_cache='./cache')
with SyncCrazyflie(URI, cf=cf) as scf:
# Note: it is possible to add more than one log config using an
# array.
# with SyncLogger(scf, [lg_stab, other_conf]) as logger:
with SyncLogger(scf,[lg1, lg2]) as logger1:
endTime = time.time() + 3
for log_entry1 in logger1:
#for log_entry2 in logger2:
timestamp1 = log_entry1[0]
data1 = log_entry1[1]
logconf_name1 = log_entry1[2]
#print(data['stabilizer.roll'])
print('[%d][%s]: %s' % (timestamp1, logconf_name1, data1))
#timestamp1 = log_entry2[0]
#data1 = log_entry2[1]
#logconf_name1 = log_entry2[2]
#print('[%d][%s]: %s' % (timestamp1, logconf_name1, data1))
if time.time() > endTime:
break
Re: Data Logging
Your code works on my machine
Maybe you have to update crazyflie-lib-python?
- Member
Re: Data Logging
Just update to cflib 0.12.1 Its now working. Thanks
