Hi guys,
I've been having issues with configuring the Crazyflie firmware for the BigQuad.
I've placed config.mk.example in crazyflie-firmware/tools/make, renamed it to config.mk, uncommented "CFLAGS += -DENABLE_BQ_DECK", used ecliplse to clean, build and flash using radio...but i keep getting the solid red LEDs on the crazyflie. If I remove config.mk and flash the firm it works as per usual.
Is there an error in my process that I'm missing?
FYI, I'm using Bitcraze VM
Firmware configuration for BigQuad
c.fernandes
Re: Firmware configuration for BigQuad
The problem is most likely that the config.mk is not activated, possibly spelling mistake or no "make clean" done before compilation.
