I installed the Lighthouse positioning system according to the instructions. When I moved the copter by hand, Lighthouse positioning track is perfect. But when the copter is flying, the positioning will be chaotic and the flight trajectory is very strange(For example, it will crash everywhere or fly in an extreme direction. . .). Of course, occasionally the flight path will be good, but it is rare. I am confused about this, can anyone provide some experience?
I work with a few example, but the results were mostly very terrible.
1. PID_controller_tuner.py
PID_controller_tuner.py:
(STANDARD_HEIGHT = 0.8)
Connecting to radio://0/80/2M/E7E7E7E7E7
Connected to radio://0/80/2M/E7E7E7E7E7
Waiting for estimator to find position...
update info
pos: (0.02151080034673214, -0.009399770759046078, 0.16127389669418335)
pos: (0.02156354859471321, -0.009443090297281742, 0.1609809249639511)
pos: (0.02147091180086136, -0.009354745037853718, 0.16114073991775513)
pos: (0.02161705680191517, -0.00943225622177124, 0.1609116643667221)
pos: (0.021552152931690216, -0.009350746870040894, 0.16093295812606812)
pos: (0.021576885133981705, -0.009450281038880348, 0.16106043756008148)
pos: (0.021441571414470673, -0.00933371763676405, 0.16107255220413208)
pos: (0.02149786800146103, -0.009372957982122898, 0.1612711399793625)
pos: (0.021387562155723572, -0.009492979384958744, 0.16086561977863312)
pos: (0.05385962873697281, -0.0692320317029953, 0.28011396527290344)
pos: (0.04449636489152908, -0.030371930450201035, 0.7209135890007019)
pos: (-0.09136592596769333, 0.09741857647895813, 0.8696437478065491)
pos: (-0.017205528914928436, 0.0211090799421072, 0.899692177772522)
pos: (0.01066504418849945, -0.0022861335892230272, 0.8924567103385925)
pos: (-0.0016913965810090303, 0.00845955591648817, 0.8856292366981506)
pos: (0.006614567246288061, -0.0031482211779803038, 0.8736806511878967)
pos: (0.004512520041316748, -0.004332128446549177, 0.8654157519340515)
pos: (-0.0013400246389210224, -0.0009147280943579972, 0.8559897541999817)
pos: (-0.0015537847066298127, -0.002901001600548625, 0.8507428765296936)
pos: (0.0029912476893514395, -0.001080103567801416, 0.8408267498016357)
pos: (0.00072653399547562, 0.0026213328819721937, 0.8336321711540222)
pos: (0.00161321135237813, -0.002416193950921297, 0.8466178178787231)
pos: (0.10273148864507675, -0.3012743890285492, 0.8860851526260376)
pos: (-0.013642516918480396, 0.01084250770509243, 0.580128014087677)
pos: (0.038878876715898514, 1.4567697048187256, -1.2636297941207886)
pos: (-0.15213258564472198, 3.049135684967041, -3.7532737255096436)
pos: (-0.3789260983467102, 4.5621418952941895, -6.228635311126709)
pos: (-0.6429680585861206, 6.0009684562683105, -8.700394630432129)
pos: (-0.9445403218269348, 7.362135887145996, -11.163076400756836)
pos: (-1.2841382026672363, 8.645485877990723, -13.617037773132324)
pos: (-1.6542322635650635, 9.82752513885498, -16.014699935913086)
pos: (-2.0703914165496826, 10.956052780151367, -18.454063415527344)
pos: (-2.526219606399536, 12.00582504272461, -20.88478660583496)
pos: (-3.022432565689087, 12.976350784301758, -23.307233810424805)
pos: (-3.559680461883545, 13.867060661315918, -25.721166610717773)
pos: (-4.137298107147217, 14.675846099853516, -28.121051788330078)
pos: (-4.758283615112305, 15.40552043914795, -30.516826629638672)
pos: (-5.422152042388916, 16.054147720336914, -32.9039306640625)
pos: (-6.1292805671691895, 16.621627807617188, -35.282562255859375)
File "/home/wang/projects/crazyflie-lib-python/examples/tuning/PID_controller_tuner.py", line 344, in <module>
tk.mainloop()
File "/usr/lib/python3.6/tkinter/__init__.py", line 560, in mainloop
_default_root.tk.mainloop(n)
KeyboardInterrupt
Then the plane quickly hit the wall.
the copter dont move as the postions, it flys very strange.
autonomousSequence.py:
Setting position (0, 0, 0.5, 0)
pos: (0.030154390260577202, -0.04071608930826187, 0.31477421522140503)
pos: (-0.0007748748757876456, -0.006142451427876949, 0.4711490273475647)
pos: (-0.0107026482000947, 0.025943182408809662, 0.5144262313842773)
pos: (0.00021611154079437256, 0.0031076143495738506, 0.53209388256073)
pos: (-0.002681393874809146, 0.0004751934902742505, 0.5370898246765137)
pos: (-0.0013801666209474206, 0.0018157484009861946, 0.5343238115310669)
pos: (-0.0014381464570760727, -0.0018977258587256074, 0.5320922136306763)
pos: (2.1196668967604637e-05, -0.0006699744844809175, 0.5298779606819153)
pos: (-0.00023741312907077372, -0.002970730420202017, 0.015549713745713234)
pos: (0.13737699389457703, -0.08846084028482437, 0.2902442216873169)
Setting position (0.5, 0, 0.5, 0)
pos: (-0.03106614388525486, 0.08126228302717209, 0.5744625329971313)
pos: (0.30443793535232544, 0.0537523552775383, 0.6144019961357117)
pos: (0.5658884048461914, -0.014567425474524498, 0.6227310299873352)
pos: (0.4992747902870178, 0.009026860818266869, 0.603302001953125)
pos: (0.508579671382904, -0.0030377546790987253, 0.5837059020996094)
pos: (0.5209370851516724, -0.0072291200049221516, 0.6171714067459106)
pos: (0.49307477474212646, 0.004012225661426783, 0.8271852731704712)
pos: (0.3982270359992981, -0.003186064073815942, 1.0620712041854858)
pos: (0.23960180580615997, -0.03240860253572464, 1.3043456077575684)
pos: (0.02386433817446232, -0.07567567378282547, 1.5524622201919556)
Setting position (0.5, 0.5, 0.5, 0)
pos: (-0.25042518973350525, -0.11845266073942184, 1.8152929544448853)
pos: (-0.45650550723075867, -0.10432931780815125, 2.0999069213867188)
pos: (-0.4231022894382477, 0.1190827414393425, 2.359199047088623)
pos: (-0.2910715341567993, 0.43813785910606384, 2.6099703311920166)
pos: (0.4132610857486725, 1.0333093404769897, 2.519209861755371)
pos: (1.7409334182739258, 2.020033359527588, 1.8540095090866089)
pos: (2.88242769241333, 2.8240976333618164, 1.166077733039856)
pos: (3.434795618057251, 3.1171939373016357, -0.22234320640563965)
pos: (3.767679214477539, 4.139013290405273, -3.038393974304199)
pos: (3.8838860988616943, 6.210199356079102, -6.432259559631348)
Setting position (0, 0.5, 0.5, 0)
pos: (3.631497859954834, 9.301876068115234, -10.24193286895752)
pos: (-0.020589759573340416, 0.04271910339593887, -0.4165353775024414)
pos: (-0.21874411404132843, 0.3901570439338684, -3.7565155029296875)
pos: (-0.0524086095392704, 0.010095535777509212, -1.2635126113891602)
pos: (8.00841226009652e-05, -0.00014445385022554547, -0.039487358182668686)
pos: (0.006059775594621897, -0.0029605270829051733, -2.031395196914673)
pos: (-0.0012611598940566182, 0.0009671306470409036, -0.3712517023086548)
pos: (0.10050997883081436, -0.1367504745721817, -2.986516237258911)
pos: (-7.737229316262528e-05, 4.253603037795983e-06, -0.030328713357448578)
pos: (-0.09010864794254303, 0.07761498540639877, -1.3127788305282593)
pos: (-1.1987003087997437, 1.0707621574401855, -3.9952900409698486)
pos: (0.0014176721451804042, -0.0014579802518710494, -0.007437313441187143)
pos: (0.23774608969688416, -0.24290229380130768, -0.6093873977661133)
pos: (1.3221426010131836, -1.407931923866272, -2.7383406162261963)
pos: (5.538136065297294e-06, -1.2720255654130597e-05, -0.008049752563238144)
pos: (-0.0994391068816185, 0.02828286401927471, -0.5576842427253723)
pos: (-1.0641062259674072, 0.6339820623397827, -2.338186264038086)
pos: (-2.689187526702881, 1.86649489402771, -6.673027515411377)
pos: (-1.7364801578878541e-06, 2.4220159957621945e-06, -0.02364034205675125)
pos: (-0.0004657442041207105, 0.0004666387103497982, -1.2602832317352295)
Setting position (0, -0.5, 0.5, 0)
pos: (-0.002549898810684681, -0.004757952410727739, -4.343245029449463)
pos: (5.402640454121865e-05, -9.08933870960027e-05, -0.15477758646011353)
pos: (0.0025304013397544622, -0.0011787477415055037, -1.7655665874481201)
pos: (0.009406345896422863, -0.003538606921210885, -5.1323676109313965)
pos: (-0.00011034830095013604, 0.0001379080640617758, -0.2783437669277191)
pos: (-0.003725956892594695, 0.01094147376716137, -2.2151710987091064)
pos: (-0.012303164228796959, 0.044952671974897385, -5.953046798706055)
pos: (-6.690723239444196e-05, -8.999624697025865e-05, -0.6664299368858337)
pos: (-0.0015465645119547844, 0.002271381439641118, -3.209367513656616)
pos: (6.786091830690566e-07, 2.820702604822145e-07, -0.03882521390914917)
Setting position (0, -0.5, 0, 0)
pos: (-2.162110286008101e-05, -0.00030287730623967946, -1.3723729848861694)
pos: (3.821856080321595e-05, -0.0029776415321975946, -4.5867438316345215)
pos: (-9.09837763174437e-06, 7.044474477879703e-05, -0.27334901690483093)
pos: (0.00022573773458134383, 0.001989845186471939, -2.2413008213043213)
pos: (0.00018643357907421887, 0.005837241653352976, -6.104535102844238)
pos: (-0.00015348738816101104, 0.0006159031763672829, -0.806615948677063)
pos: (-0.00011780473869293928, 0.0023421458899974823, -3.5926342010498047)
pos: (-6.7546952777775005e-06, -2.327300353499595e-05, -0.12579751014709473)
pos: (6.20216887909919e-05, -0.0007342668832279742, -1.7496511936187744)
pos: (0.0010620015673339367, -0.0005018823430873454, -5.351192474365234)
Once, the drone's chaotic flight
Setting position (0, 0, 0.7)
pos: (-0.14168664813041687, -0.15732799470424652, 0.2798379957675934)
pos: (-0.12018916010856628, 0.16307367384433746, 0.2684902846813202)
pos: (-0.0390496626496315, 0.2986680865287781, -0.2266542613506317)
pos: (-0.20433449745178223, 0.20120200514793396, -0.28798896074295044)
pos: (-0.39177122712135315, 0.04481515288352966, -0.6812000274658203)
pos: (-0.5755356550216675, -0.10842739790678024, -1.061019778251648)
pos: (-0.7693692445755005, -0.2737712860107422, -1.4654326438903809)
pos: (-0.9758564829826355, -0.4518628716468811, -1.8971816301345825)
pos: (-1.1895394325256348, -0.6364529728889465, -2.3443005084991455)
File "/home/wang/projects/crazyflie-lib-python/examples/positioning/initial_position.py", line 172, in <module>
initial_x, initial_y, initial_z, initial_yaw)
File "/home/wang/projects/crazyflie-lib-python/examples/positioning/initial_position.py", line 145, in run_sequence
time.sleep(0.1)
KeyboardInterrupt
Process finished with exit code 1
pos: (-0.11075931042432785, -0.11993246525526047, 0.30401915311813354)
pos: (-0.1050366684794426, 0.058083243668079376, 0.6101504564285278)
pos: (-0.014981936663389206, 0.03556116670370102, 0.7747489213943481)
pos: (-0.01492931880056858, -0.009511709213256836, 0.8037581443786621)
pos: (0.005674766842275858, 0.000997885363176465, 0.7979667782783508)
pos: (0.010283300653100014, -0.005211748648434877, 0.786018431186676)
pos: (0.010465807281434536, -0.006768969818949699, 0.7707411050796509)
pos: (0.009757379069924355, -0.004933073651045561, 0.7588413953781128)
pos: (0.008124609477818012, -0.005767980124801397, 0.749455451965332)
pos: (0.022570060566067696, -0.008287589065730572, 0.7493460774421692)
Setting position (-0.7, 0, 0.7)
pos: (-0.0767379179596901, -0.029863521456718445, 0.7248541116714478)
pos: (-0.5260859727859497, 0.00045625504571944475, 0.7322055101394653)
pos: (-0.6966109871864319, 0.007388170808553696, 0.7176498174667358)
pos: (-0.7032651901245117, 0.0005043466226197779, 0.7234547138214111)
pos: (-0.7084795236587524, 0.004109851084649563, 0.720493495464325)
pos: (-0.6969967484474182, 0.007976740598678589, 0.7179866433143616)
pos: (-0.6985143423080444, 0.011143175885081291, 0.715547502040863)
pos: (-0.7068672776222229, 0.006947146262973547, 0.7096388936042786)
pos: (-0.6886261701583862, 2.991433211718686e-05, 0.7049977779388428)
pos: (-0.6723108887672424, 0.0050634886138141155, 0.7071345448493958)
pos: (-0.5443704128265381, 0.008126562461256981, 0.7008529901504517)
pos: (-0.11303862929344177, -0.02329036220908165, 0.7012369632720947)
pos: (-0.0009557114099152386, -0.024654220789670944, 0.7039843797683716)
pos: (0.016133030876517296, -0.014439907856285572, 0.7141757607460022)
pos: (0.03827916830778122, -0.009921826422214508, 0.7112358808517456)
pos: (0.02819104678928852, -0.004401205573230982, 0.7071875929832458)
pos: (0.020690100267529488, -0.0025961678475141525, 0.7040784955024719)
pos: (0.015688780695199966, -0.003247329266741872, 0.703755259513855)
pos: (0.011507956311106682, -0.0008558977278880775, 0.6977506279945374)
pos: (0.008282961323857307, -9.85568476608023e-06, 0.7033833861351013)
Setting position (0, 0, 0.2)
pos: (-0.001151756732724607, -0.005175657104700804, 0.5196112990379333)
pos: (0.010652776807546616, -0.006880875676870346, 0.22007805109024048)
pos: (0.010514587163925171, 0.011607629247009754, 0.1809195578098297)
pos: (-0.00136845326051116, 0.003705997485667467, 0.1771002858877182)
pos: (-0.016999615356326103, -0.006363851949572563, 0.16647040843963623)
pos: (-0.01857483945786953, 0.005542283412069082, 0.16359539330005646)
pos: (-0.015702620148658752, -0.00029068876756355166, 0.1664767861366272)
pos: (-0.01376656349748373, -0.001262443489395082, 0.16770417988300323)
pos: (-0.004536376800388098, 0.002868087263777852, 0.17198538780212402)
pos: (0.0156106473878026, -0.002121888566762209, 0.17549164593219757)
4.trianglemove only with hand, seems very good.
