crazyflie 2.1 expansion
Posted: Thu Aug 13, 2020 9:16 am
Hi everyone,
I am a newbe in the crazyflie world, I have easily used the normal setup crazyflie 2.1+ flow deck+ multiranger. Now I would like to build a larger quad with the bolt + flow deck + multiranger + small camera (Max 15cm diagonal frame). Do you have any advice, websites or guides to understand better on how to calculate weight/props/motors/esc/battery ratio?
Thank you in advance!
