Page 1 of 2
[Solved] Nothing happens on power on
Posted: Tue Jul 16, 2013 12:02 am
by Danmark
I got my CF this weekend and flew around a couple of times on both saturday and sunday.
On Sunday night i left it in the charger and went to bed.
Monday morning i tried to turn it on and nothing happend.
So i unplugged the charger and left for work. got back from work (and a football game, we won!) and tried again. still nothing.
tested both with the battery and the usb connected and disconnected, all four variants (yes, both unplugged too :D )
Re: Nothing happens on power on
Posted: Tue Jul 16, 2013 6:25 am
by marcus
Could you try re-flashing the firmware like in this post and see if it helps?
/Marcus
Posted: Tue Jul 16, 2013 6:35 am
by Danmark
marcus wrote: Could you try re-flashing the firmware like in this post and see if it helps?
Unfotunely not. The CF does not start. no LEDs flashing or anything. so the bootloader is unable to find it.
Allthough today when i tried to plug in the usb cable it started like normal and i figured i'd let it charge for a while scince the green led was blinking. then i looked away for like two minuites and then its dead again..
Posted: Tue Jul 16, 2013 7:01 am
by marcus
So if you unplug the battery and only connect the Crazyflie using USB none of the LEDs light up?
Posted: Tue Jul 16, 2013 7:27 am
by Danmark
marcus wrote:So if you unplug the battery and only connect the Crazyflie using USB none of the LEDs light up?
Thats right.
Posted: Tue Jul 16, 2013 5:36 pm
by Danmark
I tried connecting it with USB again nut now and the blue led flashed for a split second and then it all went dark again.
Posted: Wed Jul 17, 2013 8:51 am
by marcus
Ok. And even if the blue LED is not lit up the propellers don't spin when you plug it in? Are you using a USB hub without external power? If you have a micro-USB charger for your phone could you try that instead?
Do you have a multimeter? If so could you measure the voltage of VCC? Have a look at the top placement, you can either use P5 or P6. On P6 VCC on is pin 1 and DGNG is on pin 9. Could you also measure the VUSB voltage that's on P8?
/Marcus
Posted: Wed Jul 17, 2013 9:34 am
by Danmark
the usb power is not the issue. i've tried both my computer, my laptop and my charger :)
no, no propellers spinning.
I did some measuring yesterday.
if i remember correctly
the VUSB was 5V (im pretty sure about this one)
VCC was about 0.78 V maybe 1.78V
I'll do some more measuring tonight
Posted: Wed Jul 17, 2013 6:33 pm
by Danmark
Now i've done some measuring on the CF
VCC - 0.35 V (on both P5 and P6)
VUSB - 4.99 V
1.78 was the voltage on the battery pins.
Posted: Fri Jul 19, 2013 9:15 am
by Danmark
Any ideas?
could it be a faulty power management chip?
