[SOLVED] Flashing new firmware does not actually flash?
mnjn
Post by mnjn » Sun May 17, 2020 1:13 am
I was messing around with custom firmware and flashed a simple program that just lit up the right green LED. Well, now if I try to flash the original firmware, my LED program keeps on running. I've tried it with the ST-Link, and it says it flashed and everything, but it clearly doesn't. My LED program clearly still runs.
If I try using
make cload
then it can't find my Crazyflie even though I can put it in bootloader mode (right blue LED blinking). The interesting thing is, if I simply have my LED program running, and I use
make cload
with
CLOAD_CMDS ?= -w radio://0/80/2M
set in the Makefile, it's able to find and connect to the Crazyflie and put it in bootloader mode! Except that it isn't able to flash anything to it, and exits with:
Failed to warmboot
make: *** [cload] Error 255
Anyone have any idea what could be going on?
Thanks.
Re: Flashing new firmware does not actually flash?
Post by kimberly » Mon May 18, 2020 11:59 am
If your LED program was not based on the crazyflie firmware, then I'm afraid that the original bootloader have been overwritten by your custom firmware.
You would need follow the instructions to reflash the bootloader on the STM through this forum thread through dfu: viewtopic.php?f=5&t=3225&p=15771&hilit= ... der#p15771
Post by kimberly » Mon May 18, 2020 12:12 pm
You can also use your debugger btw. If you clone this repo: https://github.com/bitcraze/crazyflie2-stm-bootloader and do
make clean
make all
make flash
This will also reflash the bootloader, and then you are able to flash crazyflie firmware code again.
mnjn
Post by mnjn » Wed May 20, 2020 4:55 am
Ah, that makes sense! I was actually able to get the Crazyflie firmware to flash onto the board again by using st-link instead of OpenOCD, but remote flashing with cload wouldn't work. Now I see why, thank you!
Re: [SOLVED] Flashing new firmware does not actually flash?
Post by kimberly » Mon May 25, 2020 10:45 am
Ah great. I guess it would also help if you know the address of the bootloader so that you can flash the custom firmware on the same spot as the CF firmware without affecting the bootloader. That might be easier for developing your own code
Let us know if you having any more problems!
