Crazyflie Bolt issue with motors
olif
Re: Crazyflie Bolt issue with motors
Post by olif » Fri May 22, 2020 6:23 am
This can also happen if the esc is not initialised. On normal quads if you have a new esc you can initialise it with the joystick of your transmitter so it knows what is 0 and 100%. So the question is how can you initialise the esc via bitcraze software.
r0b0tn1k
Post by r0b0tn1k » Sat May 23, 2020 8:54 pm
Hi all, a bit of an update.
I redid the soldering and now there's no more issues when testing the motors.
Also fixed orientation of one of the motors, so now I believe they are all pointing in the right direction.
So I ran the first test... aaaand nothing. Motors go what sounds to me like full throttle, and it fails to lift off.
Here's how the motors are turning (the diagram shows the basic crazyflie, but it's the bolt).
Here's a video of the failed takeoff:
https://www.dropbox.com/s/ctzw6pso905hg ... 8.MOV?dl=0
In the end I cancel the script so it doesnt burn the motors.
Another thing I noticed is that due to the huge vibrations, the multiranger deck slides off the pins.
Post by tobias » Mon May 25, 2020 11:34 am
Looks like the propellers are pushing instead of pulling. Front and back propellers should be switched.
I would not test with a script first, high risk of crash, but instead with joystick and holding the drone firmly in my hand to feel that is is behaving correctly.
r0b0tn1k
Post by r0b0tn1k » Mon May 25, 2020 5:54 pm
Wait, switching front and back does not make sense, as they move in exactly the same direction?
Can you draw on top of the image where the motors should be turning?
Post by tobias » Tue May 26, 2020 9:15 am
The propellers turn the right way it is just the the CW propellers are mounted on the CCW motors so they need to be swapped. This causes the propellers to push air instead of pulling it, thus pushing the quad to the ground.
