Software issue
LaBerloule
Software issue
Post by LaBerloule » Tue Mar 17, 2020 6:38 pm
I have a problem. The Crazyflie pc client can't find the device. I need help. I don't know what to do.
"INFO:cfclient.utils.input.inputreaders.pysdl2:Looking for devices
INFO:cfclient.utils.input.inputreaders.pysdl2:Found 0 devices
INFO:cflib.crazyflie:Resending for pattern (76, 1)"
Re: Software issue
Post by kristoffer » Wed Mar 18, 2020 7:55 am
Please tell us a bit more about your setup. What equipment and software are you using?
LaBerloule
Re: Software issue
Post by LaBerloule » Wed Mar 18, 2020 9:38 am
I have a Crazyflie 1 i think. I've tried client 2020 and a other client 2019 but both don't work.
It's the same problem : When I'm in the client, I trying to connect the client with the quadcopter. However the command bloc says " Found 0 devices"
Re: Software issue
Post by kristoffer » Wed Mar 18, 2020 10:04 am
First step is to figure out which type of Crazyflie you have:
Does it look like the CF 2.x https://www.bitcraze.io/products/crazyflie-2-1/ or the CF 1.0 https://www.bitcraze.io/products/old-pr ... yflie-1-0/?
LaBerloule
Re: Software issue
Post by LaBerloule » Wed Mar 18, 2020 10:45 am
It's CF 1.0 for sure
Re: Software issue
Post by kimberly » Thu Mar 19, 2020 2:14 pm
I would like to suggest to install the client from 2017, but unfortunately somebody on a similar thread tried the same: viewtopic.php?f=5&t=4218.
We are a bit unsure on how to fix this, so I will discuss it with the rest and get back to you. In the mean time, keep an eye open on the thread I've shared.
LaBerloule
Re: Software issue
Post by LaBerloule » Fri Mar 20, 2020 8:26 am
Thank you for your help. I'm still waiting for new information about my problem.
LaBerloule
Re: Software issue
Post by LaBerloule » Fri Mar 20, 2020 12:43 pm
I read the post, though I don't know how to do that:
"In the mean time, could you also downgrade the cflib to one from 2017 ? (I think you can do it as pip/pip3 install --upgrade cflib==0.1.3)"
LaBerloule
Re: Software issue
Post by LaBerloule » Fri Mar 20, 2020 1:45 pm
now I'm trying to connect to the drone and this is what it's telling me:
"INFO:cflib.crtp.radiodriver:v0.52 dongle with serial N/A found
INFO:cflib.crazyflie:Callback->Connection initialized[radio://0/10/250K]
INFO:cflib.crazyflie:We are connected[radio://0/10/250K], request connection setup
INFO:cflib.crazyflie:Resending for pattern (93, 5)
WARNING:cflib.crazyflie:Got link error callback [Too many packets lost] in state [1]
INFO:cflib.crazyflie:Callback->Connected failed to [radio://0/10/250K]: Too many packets lost
INFO:cflib.crazyflie:Closing link
INFO:cflib.crazyflie:Callback->Disconnected from [radio://0/10/250K]"
Help me...
Re: Software issue
Post by kristoffer » Mon Mar 23, 2020 11:14 am
Which operating system are you using? Are you using the virtual machine?
