Alert Sounds?
KOschi
Alert Sounds?
Post by KOschi »
hi,
is it Possible to make an Update for the Crazyflie PC Client (Or even the Crazyflie itself with this) so it makes an alert noise when
1) the batterie is allmost empty?
2) the crazyflie is allmost out of range or the links signal is really bad?
This would really help to prevent crashes.
Surrender
Re: Alert Sounds?
Post by Surrender »
Yes, it should be possible to add sounds to the pc client.
I found something on the internet, using the libary winsound:
import winsound
Freq = 2500 # Set Frequency To 2500 Hertz
Dur = 1000 # Set Duration To 1000 ms == 1 second
winsound.Beep(Freq,Dur)
Link: http://stackoverflow.com/questions/6537 ... beep-noise
Currently I have no time for anything but I will add these features like beeping when low battery or when disconnected on the crazyflie itself.
Sent from my GT-I9100 using Tapatalk 4 Beta
